Old 11-30-2015, 11:48 AM   #1
Petersb's Avatar
Overcharge
Question when my MBS is plugged in to shore power should I unplug it when it's running to circulate oil ?
Petersb is offline   Reply With Quote
Old 11-30-2015, 12:23 PM   #2
Bluepill's Avatar
Not absolutely necessary, but a good idea.
2018 Coachmen Freedom Express 192RBS
Old 11-30-2015, 12:27 PM   #3
It may save the Power cord also if you put it in Drive! Youroo!!
Old 11-30-2015, 05:22 PM   #4
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Don't understand the issue
Jeff
HomeOnWheels is offline   Reply With Quote
Old 11-30-2015, 05:50 PM   #5
MarsMan's Avatar
I do not worry about it if I need to start the MBS. The charging system recognizes there is still shore power. If my MBS is in storage mode.. I do not leave the rig plugged in.
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 11-30-2015, 09:55 PM   #6
Do not. Repeat. Do not run your Mercedes engine to circulate the oil during storage. Leave it alone! You don't do any good and the greatest wear is on a cold start. Not sitting. And your creating condensation inside the engine and throughout the exhaust system. Don't do it!
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 12-06-2015, 01:29 AM   #7
MNtraveler's Avatar
Overcharge
Well I would not run it to circulate the oil (not really needed) but also won't leave it all winter without running it. When running it, bring the engine up to temp. That will charge up the chassis battery (might take an hour,
not sure yet) and take care of the condensation concern.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 12-06-2015, 10:26 AM   #8
RedLdr1's Avatar
I take our "W" out of storage for a forty mile drive, roughly an hour drive time, every three to four weeks. That should address any oil or other fluid issues, coach battery issues, tire issues and anything else created by storage.
The only storage issue I've noticed so far is the house batteries are down to around 12.5V if I go that long. So now around the middle of the "drive" schedule I stop in and run the generator, under load, for an hour or so to charge the house batteries while I check on everything else. The only issue with that is it totally screws up my MPG calculations!
Wayne and Christine
2019 Sunseeker 2500TSF "Goldilocks"
RedLdr1 is offline   Reply With Quote
Old 12-06-2015, 10:46 AM   #9
1. Idling the MB while running the generator for an hour is not really a good idea.
2. the alternator puts out WAY more charging current while underway than the on-board converter powered by the generator, so just drive a little longer for the same effect.
3. to exercise the generator you CAN run it while underway. Run The AC too.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 12-06-2015, 05:55 PM   #10
RedLdr1's Avatar
1A. I fully agree and I do not idle the unit. I don't even open the cab doors much less start the MB while doing the generator runs. Taking off and putting back on the ADCO windshield cover alone is a total PITA since it hasn't stretched much yet...
2A. I think you may have missed the point that the house batteries drop in voltage between my roughly monthly drives. Driving it longer won't change that issue as the house batteries are fully charged after a "loop". So I slip in the generator run, midway between drives, to keep the house batteries charged between drives. I have a genset so I may as well use it...
3A. I would but as I said above it wouldn't resolve the house battery issue I'm addressing with the separate generator run.
The only reason I do the separate genset run is to keep the house batteries fully charged between monthly drives. If the house batteries didn't drop so low I would do my monthly drive running the genset with the house A/C on to address everything in one visit.
Basically I end up in our MBS approximately every two weeks. If I have any serious issues; leaks, mice, or theft / vandalism hopefully I'll catch them a little quicker with this schedule.
Wayne and Christine
