Old 09-18-2016, 07:31 PM   #51
Rkloud9
What did you do on the bottom of the cabinet where you have a high lip in front?
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 09-18-2016, 10:47 PM   #52
Rkloud9's Avatar
Hmmm... I forgot about that detail. Just took a look, and there is a piece of plywood under the bottom container, and I think it is about 3/4" thick. This raises that container just enough so that the drawer clears the lip. The plywood only needs to roughly fit the bottom of the container, as the foam keeps the containers centered in cabinet cavity.
I apologize if this missing detail caused you problems.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Bob & Cynthia
Rkloud9 is offline   Reply With Quote
Old 09-21-2016, 12:10 PM   #53
Thanks to all who posted on this thread. As we are a bit "mechanically challenged," I like the Container Store drawers.
I had drawers in our previous RV, a Class B, and found that they were often difficult to slide open when filled.
Have you, RKloud9 or Nancyc7 experienced any problems with your drawers? Especially if you have canned goods in them?
Thanks!
We have a Sunseeker 2430 GTS. The floor plan is the same as a Sunseeker 2400W but it is a gasser.
Gizmosmom is offline   Reply With Quote
Old 09-21-2016, 12:17 PM   #54
River Forest Sunseeker 24
HA! that's why I like this idea so much. My husband is mechanically inclined but certainly not a cabinet maker or a really good carpenter like some of these ideas require.
I have not been able to install ours yet but I have everything. The plywood "floor" is not cut yet. I think I will be able to do this all by myself.
Ours is in the shop for 6 weeks!! now. It's the "after you bought it tune up" of 6 items.
Nancyc7 is offline   Reply With Quote
Old 09-21-2016, 12:42 PM   #55
Hi. I just wanted to provide a tip regardless of what pantry solution you go with. Make sure you measure the width in the front as well as the back on the top and bottom. I had over 1/2 difference on mine.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 10-31-2016, 11:37 PM   #56
Well, we got ours out of the shop after 12!!! weeks, and I put in those boxes of drawers in.Rkloud9, they fit so awesome!! It's amazing. I had left over thin yoga mats from lining drawers and I stacked up enough to replace the piece of plywood at the base. The 5 drawers fit right in. We had some pool noodles left over and pipe insulation to cut in half. My husband didn't think that part was entirely necessary but the top drawer, when full and open, would pull over the entire stack, push up top shelf and dump everything out. Maybe when they all got full it would work but I'm not sure. The 1/2 pipe cover or pool noodle shoved down each side kept them steady. God forbid anything rattle anyway. I would post a photo but I don't know how and it's the same as your set. Thank you for showing this. It's so helpful.
Old 10-31-2016, 11:46 PM   #57
Name:	ImageUploadedByForest River Forums1477975458.501273.jpg
Old 11-01-2016, 06:04 AM   #58
Rkloud9's Avatar
Glad they worked out for you! 12 weeks in the shop! Yikes!
Bob & Cynthia
Bob & Cynthia
Old 11-01-2016, 07:55 AM   #59
12 weeks! If RV places gave out loaners while they were servicing, this lead time would magically shorten.
The boat, car, lawnmower and motorcycle industry can't get away with this length of service times. Why does the RV industry?
I have yet to take mine to service and have luckily fixed everything myself but 3 months seems to be the norm. That's terrible.
Old 11-01-2016, 10:05 AM   #60
Thanks!
Well you can see, we don't have a lot of stuff yet. I do think they could be difficult to pull out if packed with something as heavy as a lot of canned goods.
We don't have much canned goods at home? Tuna, sardines and coconut milk is what I see right now. Apparently we eat a lot of frozen food. Obvs, we have to think all this through a little better.
I did pack the top drawer with heavy stuff and that's when I discovered pulling the drawer out would tip over the stack without stuffing the insulation down the sides.
But, since we don't have KSun, the finish carpenter at home, these drawers are a stellar idea.
