Old 07-03-2016, 07:17 AM   #1
Prism 2200
I just downsized from a 42 footer to the 2200le a few days ago. I'm really liking my decision to do so as everyday gets a bit more comfortable. The only issue that I have found is that my water heater is anything but warm. When I go out to the panel and check the relief valve it's warm but anything like scolding as it is supposed to be. This unit is gas only water heater, which I plan on changing very soon. I'm thinking that it is getting too much cold water mixed in?? I can't find the temp control setting if there is one. I can't find the valves to see if it is in winterization mode. Any help would be appreciated.
adjusteraaron is offline   Reply With Quote
Old 07-08-2016, 03:26 PM   #2
On my 2150le, there is no (easy) way to adjust the heater temperature. My valves are behind a drawer directly beneath the reefer.
pnashdc is offline   Reply With Quote
Old 07-08-2016, 03:27 PM   #3
Yep... That's what it was. Mine wasn't bad to get to. 4 small screws.. The idiots left the valve open in the middle.
