Prism 24G - Adding outside door latches
The rear compartment on my Prism 24G with rear bed slideout does not have a latch to hold the compartment door open - I realize this is due to possible damage if one were to put the slide out with the door latched in the up position.
Has anyone added the latches anyway - they will have to mount on the slide itself, which I assume is probably fiberglass - I'm pretty sure the outer trim on the slides is metal.
The same goes for the door to the generator compartment - which needs to be open to access the holding tank drain valves (maybe not a great design?)
I don't see any way to add the little spring/gas loaded cylinders that hold doors open.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
