Old 11-20-2015, 12:02 PM   #1
Propane Capacity
I had read a post where someone had a larger propane tank installed at factory. I just inquired to FR and was told by Warranty Administrator Russel Stull, that FR would not accommodate that as it skews the overall weight and balance of the unit. He also said MB does not allow extra stabilizers or leveler a on front. Just FYI as these seem to be two areas some want to improve.
Dogpa
dogpa is offline   Reply With Quote
Old 11-20-2015, 02:44 PM   #2
MNtraveler's Avatar
Dogpa
That explains why the 4-point automatic leveling system is not an option on the MBS line. Thanks.
MNtraveler is offline   Reply With Quote
Old 11-20-2015, 03:42 PM   #3
MarsMan's Avatar
How big of a tank comes on the Solara? 10 gallons?
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 11-20-2015, 05:25 PM   #4
I think mine is a 12 but too small to consider hooking a quick disconnect for a BBQ run the gen stove and heater. Guess will carry an extra tank.
Dogpa
Old 11-20-2015, 05:52 PM   #5
MNtraveler's Avatar
The current MBS models come with 9.8 gals. At 4.24#/gal., that's 41.55#. At 80% fill capacity, that's 7.84 gals. or 33.24#.
According to Onan specs on LPG usage for the 3.6K generator that comes with these units, the run time (excluding any furnace, stove or oven usage) is as follows (usage specs from Onan, hours calculation is mine):
No load: 0.4 gal. or 1.5 lbs./hr. Run time: 19.6 hours
Half load: 0.6 gal. or 2.4 lbs./hr. Run time: 13 hours.
Full load: 0.7 gal. or 3.1 lbs./hr. Run time: 11.2 hrs.
Someone please check my math. However I used gallons in each case. If you look at the Onan numbers, they are not consistent across the range between gallons and pounds. They used a conversion factor ranging from 3.75 to 4.4 lbs./gal. for reasons unknown.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
Old 11-20-2015, 06:26 PM   #6
MarsMan's Avatar
For some reason mine came with 20 gallons. On a spec sheet it said optional. However, I did not ask for it. Perhaps on the Prisms with a LP genny they bump it up
MarsMan
USN-R '01-present
Old 11-20-2015, 06:52 PM   #7
RedLdr1's Avatar
The new Isata MBS comes with a 20 gallon tank as well...
As for front levelers M-B does not allow any welding on the frame by up fitters. I was told by Bigfoot they are working on a M-B approved front set. It will supposedly allow the reuse of the FR rear "stabilizers" as part of the upgrade.
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 11-20-2015, 07:05 PM   #8
tnjmich's Avatar
tank size
I believe the 9.8 gallons is the net size, not the gross. We are about to order a 24S. I went to the Hershey PA show and talked to the factory rep about this. My concern was the tank is so small if you boondock, especially if you need to run A/C. The factory rep said they we considering offering a larger tank, but nothing was firm. He also said the tank was 12.2 gallons which yielded 9.8 gallons of useful capacity.
We decided to go forward, and will add an Extend-A-Tank fitting and travel with a spare 20 lb tank when we go dry. Then we can run off the portable tank and easily swap tanks without having to find a refill station.
tnjmich is offline   Reply With Quote
Old 11-22-2015, 06:43 PM   #9
tanks are 12.2 gals, 80% fill gets you to 9.6gals net. I added an extend-stay fitting and bought a composite tank thru amazon (much lighter) to carry as an extra. I added a low pressure quick connect for my grill. It's the generator that uses the most LP, but when you need it (a/c in the summer while traveling in hot weather) you'll probably be willing to fill up more often. Sprinters are a series of compromises, to gain the agility of the smaller form factor.
jdyson
(former owner, went back to Class A)
(but enjoyed our brief 'experiment' in downsizing!)
'16 Forester MBS 2401R
Hellwig 7254, TireMinder A1A & Sumo Equipped
jdyson is offline   Reply With Quote
Old 11-23-2015, 07:58 PM   #10
RedLdr1's Avatar
Very true... To avoid this particular compromise I went with the optional diesel generator.
Wayne and Christine
propane
