Old 12-08-2015, 12:31 PM   #1
CharSolera's Avatar
Propane Extend a Stay - MBS
Those of you with extend a stay propane tanks with a MBS, how are you carring the additional propane tank when you're on the road?
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 12-08-2015, 02:48 PM   #2
Pod2Vibe's Avatar
In the drivers side far rear bin, is where I keep mine.
Pod2Vibe
Magnetic 2019 Isata 5 30FW 4X4 (arrived 2/15/19)
TOAD: 2014 Fiat 500 Abarth
2015 Solera MBS 24R - Hellwig/Sumo Equipped, Sold
(Sold the Vibe TT, as well)
Pod2Vibe is offline   Reply With Quote
Old 12-08-2015, 05:19 PM   #3
CharSolera's Avatar
Pod2vibe, did you add ventilation to that bin? Folks told me it's not saft to transport the cylinder inside of an enclosed bin (as that WAS how I was planning to carry the tank).
Charlene
2014 Solera 24S
Old 12-08-2015, 05:51 PM   #4
2012 Solera
Driver's side far rear bin (the one just forward of the utility compartment) is not enclosed on our 2012 Solera "S". Top is open to the outside.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 12-08-2015, 06:08 PM   #5
CharSolera's Avatar
Good to know, JLeising. I have a 2014 Solera and all compartments are enclosed. I'd really like to have a way to carry an additional 20# tank, but I don't see a safe way to do it on my rig. 😞
Charlene
2014 Solera 24S
Old 12-08-2015, 07:35 PM   #6
I have a 2016 R and I installed a dual valve with extended stay capability and BBQ valve. I store the extended stay tank in 6x12 that I tow. Plans to run a 15' BBQ line under unit and frame members to storage area on pax side so BBQ can be used under awning. Valve was 50.00 so not bad.
dogpa
dogpa is offline   Reply With Quote
Old 12-08-2015, 09:02 PM   #7
Petersb's Avatar
CharSolera. Have you given any thoughts to having louvered vents cut in the storage bin we had that done in another Mh so we could carry oxygen tanks that my in law had to have.
Petersb is offline   Reply With Quote
Old 12-08-2015, 09:09 PM   #8
CharSolera's Avatar
Petersb, that back storage area is very large on my 24S. I sure wish the propane capacity on the Solera was higher. I think its interesting to hear the Coachman Prism tank is larger than the Forester, Sunseeker or Solera. Adding ventilation is an option.
Charlene
2014 Solera 24S
Old 12-08-2015, 09:47 PM   #9
Pod2Vibe's Avatar
Sorry, I should have mentioned that the R model has a huge rear bin "area" that is a pass through and includes 4 bin doors. It is not very sealed. I also keep my bin drain holes open when I have propane inside. When I get to my destination, the tank comes out, as well.
Pod2Vibe
Old 12-09-2015, 02:06 PM   #10
milvet33's Avatar
Propane tank storage
Not sure why all the hoopla over carrying propane bottles. I've been carting a 20# bottle for an Extend a Stay in a closed compartment on my Sunseeker for 8 years. Actually I consider travelling down the road with propane in use (refrigerator, furnace etc), like some folks do,to be a greater hazard to life and limb.
milvet33 is offline   Reply With Quote
Old 12-09-2015, 02:50 PM   #11
Pod2Vibe's Avatar
It is a weight issue. I recall that the Prism has a lower, 3500# towing capacity.
Pod2Vibe
Old 12-09-2015, 08:38 PM   #12
CharSolera's Avatar
Good to know, Pod2Vibe. I don't tow, so I'd really like to have that extra capacity.
Charlene
2014 Solera 24S
Old 12-10-2015, 01:09 AM   #13
MNtraveler's Avatar
Another option is a storage shelf attached to the hitch. For the R model, be sure not to block the slider or else tape off the slide switch until you remove the rack when parked.
I'm sure everyone has an opinion, but I wouldn't put one in an enclosed space, especially part of the MH. I won't even put my grill tank in the garage in the winter. Propane tanks stay outdoors, period.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 12-12-2015, 02:03 PM   #14
CharSolera's Avatar
MNtraveler, I have a bicycle carrier on the hitch 😢. Yes, I'd only consider having the tank in a ventilated compartment or outside.
Charlene
2014 Solera 24S
Old 12-14-2015, 04:25 PM   #15
I keep a couple of the small ones for my grill in an exterior compartment. Prob not the best idea but I don't have a ventilated compartment in my 2401R.
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
propane
