Should the fill nozzle on the propane tank have a o ring?
I was getting my propane tank filled and they wouldn't do it because they couldn't get a good seal. My RV is less than a year old and has only been filled two times without problems. I figured it was the filling place problem so I went to a second place and they had the same problem.
Luckily they went ahead and filled even though it was leaking on the connection because we were going into Yosemite for 3 days without hookups. He did say he thinks we may of lost an o ring.
Can someone with a similar model of ours check to see if it should be bare brass connection or if it should have some type of o ring seal?
Thanks.
2016 Sunseeker W MBS
