Old 07-20-2016, 03:41 PM   #1
Propane leak when refilling
Should the fill nozzle on the propane tank have a o ring?
I was getting my propane tank filled and they wouldn't do it because they couldn't get a good seal. My RV is less than a year old and has only been filled two times without problems. I figured it was the filling place problem so I went to a second place and they had the same problem.
Luckily they went ahead and filled even though it was leaking on the connection because we were going into Yosemite for 3 days without hookups. He did say he thinks we may of lost an o ring.
Can someone with a similar model of ours check to see if it should be bare brass connection or if it should have some type of o ring seal?
Thanks. Click image for larger version
Name:	ImageUploadedByForest River Forums1469047216.313421.jpg
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 07-20-2016, 04:18 PM   #2
Yes it should have a gasket.
Here's a Youtube video that shows it very well.
Gotta go campin!
Old 07-21-2016, 11:31 PM   #3
Thanks so much I will have to stop somewhere like camping world and pick one up - we still have to cross the country to get back home!
Old 07-22-2016, 04:45 AM   #4
Attachment 114770
Wow, since the filling port on a permanent propane tank is built to an industry standard, you would think that the filling stations would have replacement gaskets on hand.
It sure seems like the filling station operator wasn't properly trained or they should have known about the gasket and done a visual check once they could not get a good seal.
BTW nice paint scheme. We have that same paint scheme on our MBS2400WS. Since there is just the two of us we ordered the trekker cap instead of getting the cab over bed. I think the WS" is for the trekker cap configuration. I am not sure if you have one yet or even considered getting one. AdventureRV.net has a real good price on the Carefree SunBlocker EZ Zipblocker Awning sunscreen.
Name:	sunscreen installed.jpg
ShermanD is offline   Reply With Quote
Old 07-22-2016, 06:59 AM   #5
I would think most real propane dealers would have them on hand, but probably not filling stations.
Post back where you find one, as I'm sure other people would line to know where to find them.
Gotta go campin!
Old 07-22-2016, 08:24 AM   #6
Do this; try and determine what brand the brass fill connection fitting is installed on your tank. Do a reach out to FR here possibly. Then, research "propane tank re-cetification" facilities on your travel path. I think that is a good place to start .Otherwise, you will become frustrated on how inept most fill stations truly are. I have had on more than one occasion, Herculean attempts to cross thread my propane fitting by "trained " fillers.
Old 07-24-2016, 10:41 AM   #7
sgtlm17's Avatar
Propane dealers yes they will know. Iv'e found gas stations only know how to fill 20lb BBQ tanks. When you pull in with your rig they look at the tank for ten minutes and still do it improperly.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 07-24-2016, 11:36 PM   #8
We felt very fortunate that the chevron filling station guy didn't care that it was leaking and filed it anyway before we went into Yosemite for 3 days.
We are in Lake Tahoe now I am going to stop at next RV service or camping world location to see if they have the O ring and will post the part number.
Good idea on the recertification station.
Old 07-25-2016, 03:01 PM   #9
Farkasb's Avatar
Nice, I have the same color scheme too! With entertain center but have the large cap, bought before they offered the Trekker.
What size EZ Zipblocker did you buy?
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 07-25-2016, 03:22 PM   #10
15 x 8. it just about touches the ground when hanging straight down but I figure I will angle it out when I use it giving us a little more floor space. It is nice heavy duty material but the reason I like it most is that it is two pieces which are zippered together. The top half stays on the awning roller and gets rolled up with the awning itself.
It will just fit the Dometic awning roller but is about 2" larger on each end than the awning on the Sunseeker. I haven't got around to it yet but plan on covering the exposed portion with Gorilla heavy duty clear repair tape for protection from the elements when the awning is retracted.
Old 07-25-2016, 03:23 PM   #11
Old Enough to Know Better
gasman6674's Avatar
Its called a 1 3/4 acme gasket, any full service LP dealer (Amerigas, Ferrellgas,Suburban etc) will have them. Most camping stores and cylinder refill dealers wont know what your talking about. Call around and save your self some running.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 07-26-2016, 11:44 AM   #12
Thanks perfect timing will be trying to locate tomorrow!
leak, propane
