Old 01-25-2018, 02:38 PM   #1
Mikegjax's Avatar
Propane Regulator
Just finished replacing my upper propane regulator. The regulator was leaking at the vent. Very obvious leak as you could hear and feel the gas escaping.
Very easy to replace. For anyone that is a DIYer like myself I suggest you disconnect the hoses at the chassis connection before disconnecting from the regulator.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-31-2018, 07:17 PM   #2
Replaced My Regulator As well
Picked up our new 2401W MBS and when the outdoor temp dropped below freezing the furnace shut off. Turned on the stove burner and then restarted the furnace. I watched as the flame on the stove almost went out. Must have been some oil or moisture in the regulator. Had it replaced and all is well.
westerm52 is offline   Reply With Quote
Old 02-07-2018, 11:58 AM   #3
Is there more than one propane regulator?
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 02-07-2018, 12:25 PM   #4
Brother Les's Avatar
this may answer your question
Brother Les
Old 02-07-2018, 02:44 PM   #5
Mikegjax's Avatar
My 24R has two regulators. If you have a diesel gen set you probably have only one.
2014 Solera 24R
USN Retired
Old 02-07-2018, 03:04 PM   #6
My 24R has a propane genset. I know where the one is on the tank. Where is the upper one?
John Craft
dogpa
2016 Solera 24R
Old 02-07-2018, 06:38 PM   #7
Mikegjax's Avatar
Both of mine are on the tank. One above the other.
2014 Solera 24R
USN Retired
propane
