05-20-2016, 03:56 PM
Question for those who change their own oil
My 1st oil and filter change today at 8500 miles. Cost about $85 dollars when buying Mobil 1 ESP on sale for $6 a quart. Easier than changing oil on my car. My question: I noticed that there are a couple of ounces of oil at the bottom of the oil filter sump that doesn't drain. Is that normal? I took some rags and wiped the oil out.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
05-20-2016, 04:19 PM
Another question- I wasn't looking closely at the large O ring placement but I assume it is the larger groove which is 2nd from top. Just want to make sure I do things correctly on my 1st change.
05-20-2016, 07:09 PM
Yes, residual oil is normal. As to the o ring, I recall just removing and replacing where I found the old one. That doesn't help you, since it appears you removed the original and can't remember which nurl it came from I assume. Is that what you're saying.
05-20-2016, 11:21 PM
where did you buy your oil and what filter did you use?
2016 Forester 2401WS MBS
Life is short...eat the cookie
05-20-2016, 11:33 PM
I quit using Mobil 1 ESP from Pep Boys, too costly. I switched to Delvac ESP 5w40 about 60,000 miles ago and oil analysis reports are good and DPF seems to be doing good. I save almost $4/quart with the Delvac ESP versus the Mobil 1 ESP. Delvac isn't MB certified but I no longer care. I change oil every 7500 miles and 90% of my driving is highway driving.
I have a 3.0L MB engine in an 07 Grand Cherokee.
05-21-2016, 09:33 AM
NAPA occasionally has the Mobil One on sale for around $6 a quart. They don't carry the ESP in the store but it arrives in a couple of days. The filter is a Mann HU821X found on Amazon for $10. By a google search I found that the larger O ring goes in the 2nd from the top (largest) grove. Apparently many people put it in the top groove resulting in oil leaking. As far as oil capacity this forum and the Solera forum list varying amounts. My book says 3.3 US gallons so if my math is correct I calculate to 13 quarts and 6.4 ounces.
05-21-2016, 11:07 AM
I read somewhere not to wipe the residual oil out of the filter housing. Don't ask me where. I wipe out mine and replace with fresh oil.
2014 Solera 24R
USN Retired
05-21-2016, 03:59 PM
RailwayRog
That might be so that the old oil is soak up by the new dry filter to prevent a collapse on the first start up after an oil change.
Had that issue on KTM motorcycles.
And yes I would wipe up old oil and soak new filter in clean oil, a little messy but doable once you get the knack for it.
05-21-2016, 04:06 PM
I pulled the filter cover after I ran it just to check. Oil is back in the filter sump and the filter is in good shape.
05-21-2016, 04:19 PM
On my 2007 3.0L mercedes benz turbo diesel, the factory specifies in a TSB that 1/2 of the oil must be poured down the oil canister filter assembly to prevent damage to the front bearings on the first start after an oil change.
I hope newer 3.0Ls have been improved so this isn't a rquirement anymore. It takes forever to pour 1/2 the oil down that way.
05-21-2016, 08:13 PM
Hear that MB dealers recommends changing oil at least annually. Here is the straight scoop from The MB Sprinter (2013) maintenance documents.
2014 Solera 24R
USN Retired
05-22-2016, 08:59 AM
Yeah, I can confirm the 2 year interval. First, I called MB after a bit more than a year and the rep said (more or less) "Don't change it until the computer tells you to." And then, a few days ago, with about 9,000 miles and 2 years on my Solera, the computer began counting down the days. I changed the oil, reset the computer and now, I guess, I'm good for another 15,000 or 2 years.
Dave
PS: I had an oil analysis done a few months and not too many miles ago. The analysis showed the oil was fine at the time.
2015 Solera 24R
2014 Mercedes Chassis
06-13-2016, 02:24 PM
Ok, so I have about 15 months and 15,700 miles on our Solera 24W. Should I wait to see the light? Just wondering. Thanks...
06-13-2016, 02:56 PM
Who Dares, Wins
I've always followed the light / gauge on my recent vehicles. But I heard / believe they say OR at least once a year.
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
06-13-2016, 04:19 PM
15,000 or every 2 years. Could wait on computer, but would er on safe side.
2014 Solera 24R
USN Retired
06-13-2016, 07:20 PM
I changed mine yesterday with 5000 miles on it. I bought it new in January and it was shipped to the dealer in December. The chassis was built in April 2015. Who knows how many times it was started and stopped before it was warmed up. The filter looks like it may be spent by the way the pleats look. I'm glad I changed it. I'll be changing oil and filter once a year regardless of mileage unless it goes over 15k. I check the oil every time I fill up. Never has used any. The book says it will.
06-14-2016, 06:20 AM
I cannot disagree - maybe I do the same after warranty expires but NOT before!
