Old 08-17-2015, 03:30 PM   #1
Questions on MBS series
I am looking at the 2401R and 2401W.
1. Does either dinette convert into a bed? What advantage does one have over the other?
2. Looks like neither plan give you a good view of the tv. Which do you like best?
3. Does the engine A/C keep the cab cool enough in 100 degree weather or do you have to run the RV A/C?
4. Since the propane tank is so small where can we carry an extra?
5. Can you delete the generator, and if so will two Honda EU2000's and my Berg tank fit in that compartment?
6. What are the R values of the coaches sides, roof and floor?
7. If you sleep in the bunk above the cab is it hot up there? (does the rv have ductwork?)
sorry for all of the questions.
camperboy is offline   Reply With Quote
Old 08-17-2015, 03:49 PM   #2
Class C Representative
Joshua Cavitt's Avatar
1) They both convert into a bed. It just depends on the style you want to sit in. There is more room with the U dinette but you can't sit directly across from each other.
2) I'll let someone else hit this question.
3) You would probably need to turn on the RV A/C. If you were just sitting in the cab it should keep you cool but it would take a while and a lot of work to keep your whole unit cool.
4)There are plenty of compartments to store your extra tank but the one on board should last a little over 2 days.
5)That's a special order request you would need to talk to your dealer and territory rep about.
6)We have an R value of 9.5
7) We run a duct over the cab so sleeping up there is comfortable.
Joshua Cavitt is offline   Reply With Quote
Old 08-17-2015, 03:54 PM   #3
Thanks for the responses.
R9.5 for all surfaces?
Old 08-17-2015, 04:40 PM   #4
Farkasb's Avatar
In the 2401W can the U dinette table and pole be completely removed to be used like a couch?
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 08-17-2015, 04:51 PM   #5
Yes it can be. If you wanted you could even set the table on the ledges like you were setting the bed up, leave the two side pieces in and use it as a love seat.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-17-2015, 06:55 PM   #6
What is the width of the dinette? Is the width the same for both units?
Thanks again
Old 08-17-2015, 08:07 PM   #7
RedLdr1's Avatar
We just picked up our "W" today and here are my observations on a couple of your questions.
2. The view of the front television, while seated at the dinette, is very good in the 2400W. (We have the optional entertainment center with the larger screen TV but it is in about the same location as the smaller TV in the bunk version.) The view of the second television in the bedroom is excellent.
3. It was 90F and raining heavily today in Atlanta. The cab A/C kept the cab area quite comfortable.
4. Rather than carry more LP another possible solution is to order the optional QD3200 diesel generator. It avoids the shorter run time issues with the LP3600.
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 08-18-2015, 08:42 AM   #8
The U-Dinette is 45x82.
Old 08-18-2015, 10:54 AM   #9
Thanks, you have been mighty helpful.
Old 08-18-2015, 11:23 AM   #10
RSchleder's Avatar
I have had motorhomes with both diesel and propane generators. Believe me, although they both work great, continually having to fill the propane tank is a real pain in the butte. Utilizing the diesel in the motorhome tank to run the generator is a much more tolerable situation. The propane generator will be quite a bit less money, however, over the long run, the extra money for the diesel gen set is money well spent!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
