Old 08-04-2016, 11:14 AM   #31
Loefflerh's Avatar
Brian, maybe you can answer the question I had before regarding brand new valve extender on a Forester: (post18)
what is beneath that shiny valve extender? still a rubber valve standard from Mercedes? And the main question is can those extenders take the weight / load of TPMS sensors?
Thanks Hans
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - ?
Loefflerh is offline   Reply With Quote
Old 08-04-2016, 11:22 AM   #32
GM
bclemens's Avatar
beneath is just stock Mercedes. So unless that changed that, its still rubber.
I doubt you would want the centrifugal force of TPMS on those.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-04-2016, 06:10 PM   #33
At the risk of being pillaried here, I like the Airflexx extensions.
namusmc is offline   Reply With Quote
Old 08-05-2016, 12:09 AM   #34
Loefflerh's Avatar
PDI done all systems work, no scratches and or damage.
Started to drive home but from the initial move squeaking noises - horrible -from the cab over. Did not even leave the dealers lot, just a couple of circles in his lot and left it for them to work on...Very disappointing but not acceptable. Will be interesting how they fix that!
Anybody knows what causes those annoying squeaks and has it experienced? Its my 3rd motor home, had never any issues.
Retired military
Old 08-05-2016, 07:19 AM   #35
Mikegjax's Avatar
I would like the Airflexx if they were mounted to metal stems and I did not have an external TPMS.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-05-2016, 04:36 PM   #36
Loefflerh's Avatar
Cudos to my dealership - they worked hard and solved the squeaks - to my understanding a metal brace underneath the cab should have been rounded off; it was metal on metal causing the noise.
Finally brought her home!
Hans
Retired military
Old 08-06-2016, 10:30 AM   #37
Brian: Agree that it was QC on the Airflex side, not a poor solution on FR side. Dealer I was stopping at offered this solution and thought I'd give thread readers idea on cost. You just remove cap and one small nut and they come off the bracket so the wheel cover can be removed.
HappyHikeRs is offline   Reply With Quote
Old 08-06-2016, 01:32 PM   #38
Mikegjax:
Thanks, I'll keep an eye on the wheel covers.
Old 08-06-2016, 02:11 PM   #39
2012 Solera
Wire tying the wheel covers to the wheels (UV resistant wire ties) is cheap, easy insurance.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-07-2016, 03:57 PM   #40
I think Brian was referring to
wheel covers that work loose and fly off the wheel, ripping away any extensions and sensors attached to it.
