Old 06-14-2016, 08:13 PM   #1
Rear Slide
What was the truck to get the rear slide out if it won't move. It's on a 24R.
John Craft
dogpa
2016 Solera 24R
Tow 6X12 Enclosed
dogpa is offline   Reply With Quote
Old 06-15-2016, 10:38 AM   #2
I guess I am the only one that has had this problem. It lasted for several hours that rear slide would not go out or all the way in. My research indicated all fuses to be good and I finally just manually pushed on one side of the slide and when activating the switch it worked. I cycled the slide in and out several times and it seems ok. I know about keeping the motors in sync and have done so.
John Craft
dogpa
2016 Solera 24R
Tow 6X12 Enclosed
Old 06-15-2016, 10:52 AM   #3
raspivey's Avatar
Schwintek slide, I'm assuming? I'd find the controller box and see if it's flashing any codes if it does it again. Most likely one of the sensors got a little out of alignment and pushing on it fixed it.
Old 06-15-2016, 11:08 AM   #4
dogpa: If you have any of those doors that look like cabinet doors, but have an extra hinge where the knob should be, so you have to remove the hinge to open it, the controller's probably behind that.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-15-2016, 11:48 AM   #5
Pod2Vibe's Avatar
Not the case in a 24R...
Look in the bin with your winterizing valve and you will find the controllers for the slides behind it. This is specific to a 24R. Any others will just confuse the OP.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
slide
