Old 04-06-2016, 06:53 PM   #1
Mikegjax's Avatar
Rear Turn Signal Issues
With the key set to on or position one my rear left turn signal only lights the center LED in both of the left fixtures . If I start engine the left rear stops flashing and the remaining LEDs are very dim.
Still in the process of trouble shooting.
My real question is for Joshua Cavitt. Are the lighting control circuit boards for a 2014 24R available should I need one? It is the circuit board located to the rear of the fresh water tank near the pump.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 04-06-2016, 09:30 PM   #2
2012 Solera
See this thread:
Curt taillight controller
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 04-07-2016, 06:05 AM   #3
Mikegjax's Avatar
Originally Posted by JLeising View Post
See this thread:
JLeising thanks. So the curt controller replaces the complete circuit board or just part of it. I know there are several fuses on the current board.
2014 Solera 24R
USN Retired
Old 04-07-2016, 09:02 AM   #4
Mikegjax's Avatar
Problem solved! Found a partially blown10 amp fuse, replaced same and all is well. When I did the fuse continuity check it showed the fuse was good. On closer visual inspection I could see a slight discoloration of the strip. Apparently the fuse was producing high resistance with power demand.
Much relieved. Hope this info. may help others.
For Joshua, thanks for you coverage of the forum.
2014 Solera 24R
USN Retired
