Old 06-07-2019, 08:33 PM   #1
Senior Junior Member
Hexnut's Avatar
Rear view off when driving
I have used my rear camera to keep watch of my toad, but it has suddenly quit when driving forward. It works when backing only. Side cameras work. Anyone have any ideas?
2016 Sunseeker MBS 2400R
Hexnut is offline   Reply With Quote
Old 06-07-2019, 08:50 PM   #2
Hexnut's Avatar
Limp Mode
I have had issues with the 3 ABS lights coming on the instrument panel, but they went away so I forgot about it. We were recently on a multi-state trip when they came on again, but no symptoms appeared...until after a hour long traffic creepy crawly jam. Upon leaving the tie-up, the MH would not shift out of 1st gear and was in limp mode. I was lucky enough to find a sprinter service dealer 30 miles away and called MB to have it towed. The next day they had it fixed and the problem turned out to be 2 rear wheel speed sensors. MB knows this is a problem and has extended the warranty on them to 5yr/100,000 miles. What I don't understand is why you should be left stranded because ABS goes crazy. If it quits working properly it should let you know and disable itself so you can get to where it can be fixed! Sometimes old tech makes more sense.
Old 06-08-2019, 07:46 AM   #3
Mikegjax's Avatar
Have you checked to make sure it has not been selected to another source? I am also assuming you tried the manual on switch.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-14-2019, 11:14 AM   #4
I have a 2017 Forester and there's a selection on the radio console/display that turns off the view for the back camera. I don't remember what I pushed to get it back on.
Sherise is offline   Reply With Quote
