Old 09-13-2016, 07:31 PM   #1
tabeth's Avatar
Removing imitation rear rims
Does anyone know how difficult it is to remove these?
tabeth is offline   Reply With Quote
Old 09-13-2016, 07:44 PM   #2
Rich.M's Avatar
Removing them is easy with a large flat head screw driver. Just work your way around the rim prying and it will come off. It's getting it back on without damaging or denting the rim that is the hard part .
2015 Solera 24r
Rich.M is offline   Reply With Quote
Old 09-13-2016, 09:15 PM   #3
tabeth's Avatar
Thank you so very much!
Old 09-13-2016, 10:02 PM   #4
There is a center hub the is held on by two Philips head screws.
2016 Forester 2401W newbie
Beachsailor is offline   Reply With Quote
Old 09-13-2016, 10:04 PM   #5
tabeth's Avatar
Thank You!
Old 09-14-2016, 01:15 AM   #6
I use a wide flat pry bar for removing and a cheap rubber hammer to reinstall. A rubber hammer is worth the small price.
namusmc is offline   Reply With Quote
Old 09-14-2016, 06:04 AM   #7
tabeth's Avatar
Thank you!
Old 09-14-2016, 06:37 AM   #8
Here are a few items that I would consider "Must Haves" for every MB Sprinter owner. They will make your tire maintenance life a whole lot easier.
BTW, make sure you line the valve stem slot up with the valve stem prior to installing the front wheel covers or you will be either calling road service or removing the wheel and taking it to your local tire repair store. Yes, I had a senior moment.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ShermanD is offline   Reply With Quote
Old 09-14-2016, 06:54 AM   #9
tabeth's Avatar
Thank you so much for the great ideas with the links! We don't call it senior moments we call it brain freeze! Lol Thanks again!
Old 09-14-2016, 08:19 AM   #10
Mikegjax's Avatar
Once you have reinstalled the covers use plastic ties to hold them in place. They can get loose after being removed.
2014 Solera 24R
USN Retired
Mikegjax is online now   Reply With Quote
