Old 08-31-2016, 04:35 AM   #11
Rich.M's Avatar
The problem with Z brackets is the one piece design if you want to lift the panel later. You won't be able to remove on the roof side and there will be very little room to get 2 wrenches under the panel for each mount. At some point you may have to lift one for debris or replace a diode. The sticky feet are 2 parts and adjustable height. The bolt is on the outside, what you can't see in the picture is the nut welded on the back bracket. Very easy to bolt on and off. I see what you mean about surface area but I think most of the strength comes from the adhesive caulk rather than the vhb tape. The Z brackets will not allow as much coverage on the panel side. It might be fine but I can only comment on what what I have used. My panels are flat mounted, there is no ladder on my Rv and I am not going on the roof and risk a fall over a few amp hrs. The panels put out plenty of power flat mount hitting 6 amps each in full sun ( higher than rated ). I originally placed extra panels to make up for shade and flat mount losses but they seem to be less than expected.
2015 Solera 24r
Rich.M is offline   Reply With Quote
Old 09-02-2016, 05:20 PM   #12
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Was curious about the flex panels that FR puts on the rigs so I contacted Brian Clemens (who is now GM of Dynamax). He said they use Go Power or Zamp flex panels at Dynamax, and use 3M VHB tape plus self-leveling sealant for attachment. He does not recommend drilling because the roof is only 1/4 - 3/8" thick.
I've already bought Renogy 2x 100w rigid panels (direct from Renogy with 5% discount), 12x sticky feet from RV solar stores, and 3M marine sealant 5200, Dicor and Eternabond tape from Amazon. Think I'm all set
Jeff
HomeOnWheels is offline   Reply With Quote
Old 09-02-2016, 07:08 PM   #13
Rich.M's Avatar
Post a follow up when you are done with your review of the no drill bonding. One other tip, I suggest a 12v breaker in the battery case on the line to the controller. It will protect the circuit and easy to reach to turn off charge controller. I bought mine on amazon.
2015 Solera 24r
Old 09-03-2016, 02:54 PM   #14
Will do.
I bought a 30A fuse for battery per Renogy's recommendation. Now wonder if 30A is too high?
Jeff
Old 09-03-2016, 03:09 PM   #15
Rich.M's Avatar
I use a 40 amp breaker with my 30 amp controller. The controller has built in" protection circuit " that kicks in at 40 amp. The breaker is really there to protect against catastrophic failure and a welding situation from a short. Your breaker is probably right for your 200 watts at about 11 -12 amps . Also there is something called cloud edge effect when the sun comes out from behind a cloud on a partially cloudy day. Solar out put can reach 125% of panel rating. I've seen that happen on my panels at high noon. Did you choose a controller ?
2015 Solera 24r
Old 09-06-2016, 01:43 PM   #16
Yes I bought the 200w RV kit from Renogy that comes with Adventurer-30A PWM Charge Controller. I didn't upgrade or change any component, only added two fuses.
Yesterday I spent less than three hours wiring all the cables. It was much easier than I expected for my W model. I will post a step-by-step procedure and photos once I'm completely set up. Basically I wired the cables down the fridge vent from roof top (easy), opened the panel on the side (outside) to catch the cables, removed caulking to expose the hole for the propane line (easy), wired cables down to the compartment for water heater below stove (easy), then from inside coach, followed the drainage pipe to under the sink where controller will be mounted on the other side (easy). To wire the battery cables I had to work from both top and bottom to remove a lot of caulking to expose a hole for wires connecting battery and power control box. The hole is behind the heat/AC duct in the corner so it was tricky (hard). Finally, working underneath the coach, I wired the battery cables through another (uncovered) hole on the battery compartment.
This method requires just two holes to be drilled, one on side panel where controller is mounted outside for cables to go inside, and one on the bottom panel of the sink for the battery cables to go down to the lower compartment where the drawer is.
The sticky feet will arrive today. I will start sanding, cleaning, mounting the feet, and finish panel installation, cable connections within the week.
An interesting observation, while I was at my RV storage, I got on the roof and looked around. I didn't see a single solar panel on any of the dozen units around me. I was surprised.
Jeff
Old 09-06-2016, 05:17 PM   #17
Rich.M's Avatar
Your moving along quick. A few thoughts/suggestions on mounting. I would not sand too much. Take down the peaks a little but don't leave yourself with and eggshell of fiberglass. I have a permanent bond without sanding.
Fit and adjust feet to the roof before removing the tape backers. Put panel on blocks and carefully remove tape from all feet. Lower as one piece, preferably with a helper due to the size of the panel. You won't be able to move or lift it once the first foot touches.
The 3m VHB tech specs state 90% bond in 24 hours. May want to wait at least that long before adhesive caulk layer in case the tape needs exposure to oxygen.
Go over the the top of the sticky feet wings as well as the sides with the adhesive caulk. It is more like epoxy than "caulk" after it sets and will brace as well as bond the foot.
I used dicor after 2-4 weeks to allow full cure. The dicor gives a smooth finish, keeps UV off adhesive and seals edges from water intrusion. Be sure to get the dicor along the inside edge of foot under panel.
Looking forward to your pictures and post of your install. I'm sure there are forum members who are considering this method and want to hear another opinion on the install.
2015 Solera 24r
Old 09-27-2016, 05:00 PM   #18
I will post a more detailed DIY procedure but here is a quick update. I finished installation of a 200W Renogy rigid system two weeks ago, and immediately took it to a 10 day dry-camp test. I'm very happy to report that the system worked flawlessly. At times it generated up to 8.6A power and kept house batteries charged. The panels are fixed on roof with sticky feet, marine sealant and dicor. I checked multiple times after driving high speed on highway, on bumpy road, fast turns etc, the panels are very firm
Jeff
solar, solar panel
