Old 02-27-2019, 08:25 AM   #1
Replace & Rewire Rear Clearance Lights On FB MB RS
I need to rewire and replace a rear clearance light on my 2015 FR 2400RS. It's one of the 3 in the center of the back. I have a MB rear slide unit. I remove the back top molding on the inside, but there us a metal bar (I assume support for the slide) and on top of that fiber board (rear interior wire) that seems to run thru the closet (one piece) and I can not get to the lights from the inside and there is no room to do it from the outside either. How would you replace those lights (and or the rear camera)?
Does FR offer phone technical assistance as well?
oregonct is offline   Reply With Quote
Old 02-27-2019, 02:11 PM   #2
Mikegjax's Avatar
Can't help you with the lights, but I replaced my rear camera by pulling out as much cable as I could, cut applied heat shrink on each wire before soldering.
You should have found the camera connection behind that trim piece.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
light
