Originally Posted by namusmc
For those of you who switched out the Jensen with a different brand, did your AM/FM reception improve?
My main complaint with the Jensen head unit is very poor radio reception.
Poor radio reception may be due to your back up monitor. It is a known issue. On my '14 model they replaced the monitor under warranty and I could finally get reception out on the road! On my '16 model with a Jensen the reception is as good as the old rig. They must have got the bugs out of the monitors by the time my current rig was built. Neither one as good as car reception, but I have XM.
Which brings up other points: I don't like the nav in the Jensen (or on the Magnadyne in my prior unit, for that matter), so I got a Garmin with the features I wanted. I don't full time in the RV, so I got a portable XM receiver with both car and home bases. I can move the device between my RV, my toad, my other vehicle, house, cabin, etc.
I bought a pre-2006 Delphi XM model because it has a strong FM transmitter built into it, so no wires needed to your head unit. They toned the transmitter down after 2005.
I keep both the GPS and XM in the tray area above the radio. To avoid unsightly power wires hanging down to the outlets, I put a piggyback fuse tap into slot 13 of the fuse block at the driver side kick panel and ran a wire through the dash up to tray area above the radio. I drilled a small hole to run the wire up into the tray and then soldered on a 4-port outlet-- 2 cigar type/2 USB.
