Old 01-17-2016, 01:12 PM   #1
Rig won't start! 2015 Solera 24r Mercedes
We were supposed to be on the road for Florida this morning from here in Ottawa but no luck. Turn the key and "click" and then nothing. The same thing happened 4 days ago when i picked it up from the dealer. But with a jump, after 15 min of charging it started. I've had it plugged in to house power since I brought it home, plus had a battery maintainer on it 4 days now. When I check the chassis battery at the red post its 12.6v. When I climb under it I hear the click of the solenoid just above the starter but nothing else. I tried tapping the starter with a hammer (Old trick), didn't work. Any other ideas before I have to tow this to M-B dealer.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 01-17-2016, 01:59 PM   #2
Loefflerh's Avatar
Do the same test gain - while someone else tries to start the engine. I bet you see a big voltage drop. Your battery is in battery heaven.... 12.6v for a battery without load is low too and I soon as you put a load on it it breaks down...
Loefflerh is offline   Reply With Quote
Old 01-17-2016, 02:04 PM   #3
Think simple. First, if and I say if your chassis battery was near dead, a battery maintainer will not charge your battery, Not even hooked up for four days, they only maintain a nearly charged battery. Second, assuming you can't get it started and drive it to an autoparts store to have them "load test" you bat. Just jump it from under the hood connections. If you need guidance on that ask. If it turns over easily, your chassis bat needs a charge, as it is quite depleted. It IS NOT likely your starter.
Old 01-17-2016, 02:10 PM   #4
X2 on that.
Note, if you only have killed your chassis bat once, based on the age it will still have some usable life left in it, after you bring it up to full charge. Also note, that if you had the main off, while plugged in to shore power, your chassis battery was isolated from your converter and was not receiving current.
Old 01-17-2016, 02:22 PM   #5
2012 Solera
Also possible battery terminal corrosion or other terminal resistance problem. Common on older vehicles - possible on new if some installation issue. If you can check the voltage while someone turns the key, and the voltage drops precipitously, then battery or high resistance connection is the likely cause.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-17-2016, 02:38 PM   #6
2012 Solera
A number of people have reported (in the past years) a problem with fuse #23 blowing and causing the vehicle not to start. Not aware of hearing solenoid "click" in that situation however - seems people reported nothing happened when key turned to start. This thread is an example:
2011 Solera won't crank
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-18-2016, 01:05 PM   #7
No Start
Always check for a good ground and remove both cables and clean post and terminal ends. Always do this before anything else. Solves a lot of no start problems.
pdqparalegal1 is offline   Reply With Quote
Old 01-18-2016, 01:25 PM   #8
Battery would be a likely candidate. I have found batteries failing in 3 years.
Harkerr is offline   Reply With Quote
Old 01-18-2016, 01:26 PM   #9
bareftn's Avatar
One old trick if you get the old click sound,turn on your headlights and then try starting ,if your headlights go out it new battery time, ALERT FYI ALERT for all of you if you have a interstate battery distributor (not a dealer)in your area go in or call to see if they have what they call a BLEM battery, all batteries have a shelf life and when they reach that they go back to the distributor and they sell them for most places $40.00 + core. I have bought several and a 5yr battery for 40 to me is a great buy even if it only last 4 years, 6 volt or 12 or deep cell all the same price
bareftn is offline   Reply With Quote
Old 01-18-2016, 01:27 PM   #10
myclmac's Avatar
I would call AAA for a jump and they my ve able to check the battery for load on site. Possibly replace the battery. The starting battery is under the floor on the drivers side but the jump start terminals are located in the engine compartment. The (+) terminal is covered with a red plastic cap. The (-) terminal is on the side of the body or use a ground to the engine or frame. Good luck.
myclmac is offline   Reply With Quote
solera
