Old 05-16-2016, 08:37 AM   #11
Thanks for the info. I'll check to see if they have a website to order from.
wildwoodtraveler is offline   Reply With Quote
Old 05-16-2016, 08:38 AM   #12
MilCop4523's Avatar
Originally Posted by Still Kickin View Post
Thanks for the heads up on the screws. While your in your going over mode, climb underneath your unit and inspect the LP tank paint. If your're in a severe climate, you might just find some pretty good rust starting to corrode that bad boy.
Oh, we're on our own boys. Nobody is going to use stainless screws during construction.
I jsut took my tray for my LP tanks and sand blasted the rust off it and primed and painted it with Rust Bullet. 10 yr warranty against rust coming back.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 05-16-2016, 08:43 AM   #13
Send a message via MSN to Tiggerdad
Rusty threads can also mean that there is a leak getting to them. I run sealant over the top of every horizontal seam and half way down each side. Then run sealant over every screw head. Remove the strip in the channel covering all the screws and add sealant over them.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 05-16-2016, 08:57 AM   #14
MilCop4523's Avatar
and on back panels where the trim covers teh screws - replace the screws with Stainless ones but make sure they are 2 to 2/5 inch ones. We watched a rear panel literally come off a trailer 2 summers ago driving in NH. the screws are too short in that area.
I pulled mine and did what Tiggerdad stated... cover all screw heads. screws rust from the inside out no the other way around
and
Old 05-17-2016, 03:32 PM   #15
MNtraveler's Avatar
Unit only 7 months old and when up on a ladder, I just found all the screws on the exterior speaker mounts are rusted. I'll have to replace them all with stainless as you did. This is simply a part not properly spec'd.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
