Old 05-14-2016, 03:55 PM   #1
Rusting screws in bodywork and rear signals
It's been mentioned before, but I thought I'd say it again. Please Forest River, use stainless steel screws where there is moisture exposure. Almost all of the black turn signal screws were severely rusted, such that threads were gone in places. This is a 2015 model. And the heads and shafts of other screws securing basement doors and securing clips were rusting and beginning to streak the siding! Yes I live in Canada, and yes we use salt and yes I drive it in the winter to get to Florida/gulf coast in January. So what? I would venture that 50% or more of your customers either live in a temperate climate that includes snow, or live near the coast and get salt spray.
I spent a whole $5.25 on 100 8x3/4" stainless steel screws and replaced the whole lot of them. It took less than an hour... It would cost a lot less at the factory!
Rust never sleeps. Don't let it stain your beautiful rig. Get busy with a couple of drill guns. One nice thing is that we have Robertson square head screws. So nice to use! You should try them some time.
ID:	107860   Click image for larger version
ID:	107862   Click image for larger version
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 05-14-2016, 04:28 PM   #2
Thanks for the heads up on the screws. While your in your going over mode, climb underneath your unit and inspect the LP tank paint. If your're in a severe climate, you might just find some pretty good rust starting to corrode that bad boy.
Oh, we're on our own boys. Nobody is going to use stainless screws during construction.
Old 05-14-2016, 04:33 PM   #3
Yeah kickin, I've seen the rust starting. I haven't bothered to paint the steel pipe just before the two regulators. I have added a brass extenda-stay connector there. I park the rig at the cottage all summer to use as a second dwelling. And the only shower at the property. We have no utilities at all. And the nearest propane is 50km away. So I use an external 30 lb tank so I don't drain the main tank. The rest of the tank itself isn't bad. Thankfully not a lot of stones in that area get kicked up.
Eric Jackson
2015 Solera 24R
Old 05-14-2016, 05:14 PM   #4
davel1971's Avatar
goes along with all the leaking grease seals on trailers. $1 more per seal would get them much better seals and have saved a fortune in warranty seal, bearing and brake replacement. They go cheap on everything just to get them out the door.
David & Lynn
Old 05-15-2016, 11:31 AM   #5
I have noticed a lot of mine need to be replaced and the heads are total rust color. Mine has been stored indoors and used on three trips so change out is a must!
The worst screws currently are on the zamp solar connection outlet next to the side door.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 05-15-2016, 02:29 PM   #6
Thanks for the heads up. FR I guess is like all the manufacturers. Get them out the door and let the customer worry about things like this. I live on the TX coast. I had my trailer a year. I have repainted the LP line, the steps and part of the chassis.
I looked at the LP tank supports and I will need to bring out the paint can.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 05-15-2016, 02:46 PM   #7
I call this the Forest River 98% problem.
98% of their product is a treat, 2% is cheap crap that shouldn't be used. Screws where I replace with nut and bolt, screws in thin board where I replace with toggles, screws that need a drop of Locktite or they fall out, crimp connectors that fall off and have to be recrimped, etc. etc.
As one poster said, get it off the lot and it becomes your problem to fix.
Oh yah, my favourite, the styrofoam pellets and garbage that continues to fall from the sky for years.
RussPastuch is offline   Reply With Quote
Old 05-15-2016, 03:54 PM   #8
Guys it is called "preventative maintenance"!!!
If you want to protect any investment(RV/Car/Truck/Boat/Etc) it is a must.....
I put car grease over every "adjustment bolt" under my slides and then split some plastic tubing and put over the threads..Then a tie wrap at each end to hold in place...Bolts & nuts as good as they came off the manufactured line 2 years ago!!
Jim in Halifax is offline   Reply With Quote
Old 05-15-2016, 10:32 PM   #9
Where did you find the great price on the stainless screws? Big box stores here will charge that much for 11 screws.
wildwoodtraveler is offline   Reply With Quote
Old 05-16-2016, 06:59 AM   #10
We have a local supplier, Ottawa Fastener Supply that stocks a wide variety of screws, nuts and bolts at reasonable prices. Single screws were priced at $0.17 each but a box of 100 was $5.25.
Because almost all vehicles are metric, but we still see imperial sizes on some manufacturers goods, we need to carry both types of tool sizes, and stores need to stock both types of materials. They have a great selection of both.
Eric Jackson
2015 Solera 24R
