Old 06-30-2018, 09:00 PM   #1
Rich.M's Avatar
Schwintek motor surprise on Solera 24R
Today we had our first schwintek motor fail on our side slide and we are out on the road in the Outer Banks. I like to be prepared so I have been carrying a spare motor for 2 years. Our 24R uses four motors between the 2 slides and fortunately they are all the same.
I reviewed the motor replacement video on my phone went up on my portable ladder and pulled back the outside slide gasket to expose the retaining screw and found it was a Square drive screw. That driver wasn't part of my on the road tool box!
I found square drive bit at a local ace hardware to use in my socket driver. The motor replacement takes only 5 min once the screw is out. Just wanted to share so others planning to keep a spare motor also check their retaining screw and be ready for removal.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 07-01-2018, 04:22 AM   #2
Thanks for the tip! (Pardon the pun).
Guess I need to add both the motor, along with the square drive bit to the tool kit. Along with a water pump, motor controller, inverter, water heater control board, etc. Sure wish Toyota made motorhomes and Denso made components...
Had hoped to drive MH to Alaska this year with the caravan, but driving Tundra next year instead. Don't really trust MB or the stuff riding on the chassis.
KatanaPilot is offline   Reply With Quote
Old 07-01-2018, 06:11 AM   #3
Rich.M's Avatar
I took a better look at the failed motor this morning, looks like a water intrusion problem leading to corrosion of the wire harness connections. Looks to be a slide seal problem.
ID:	177906   Click image for larger version
2015 Solera 24r
2017 Jeep Wrangler
Old 07-03-2018, 03:27 AM   #4
namusmc's Avatar
Wish some kind person would make a YouTube video showing a motor replacement in field conditions from start to finish using an actual motorhome. I have seen the Lippert videos done in a lab setting.
Sent from my SM-G920V using Forest River Forums mobile app
namusmc is offline   Reply With Quote
Old 07-03-2018, 06:53 AM   #5
I had a motor go out last year on a 2015 3171. In my case one of the wires came off the circuit board. I think a motor redesing would go a long way toward making these motors last longer.
Sent from my Pixel 2 XL using Tapatalk
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 07-03-2018, 07:25 AM   #6
Rich.M's Avatar
Sorry no video this time but the lippert video is pretty close to correct. 1) I did have to remove the outside screw to get the motor to lift. It was under the outer seal which clips on and off easily. 2) pull the black wire harness out of the space above the motor so you are left with only the colored wire harness in the space above the motor. Unplug. You will need that space to lift the motor. They show this but don't emphasize it. 3) lift motor and tip out from the bottom of the hole. - easy. 4)Insert new motor with the D on the shaft lined up as close as possible to the current d insert position, the retaining pins limit to 4 choices. 5) Push or pull your slide for the D in the shaft to line up. The motor will drop down when lined up. They show/ mention this in the video and it was easy to rotate the slide receiver for the D shaft with a little push on the slide Then just put back the wires,screw and molding the way you found them. Easier than I thought but I dread having to pull a motor on the wall side of the slide. Would need to remove the slide molding to reach it.
2015 Solera 24r
2017 Jeep Wrangler
Old 07-03-2018, 07:44 AM   #7
From the looks of that connector... even a dab of dielectric grease would have been a big help in keeping some of the water out.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 07-08-2018, 07:34 AM   #8
I agree! We have had nothing but issues! Been out of service for 2 1/2 months of the 11 months we have had it! Just got it back and needing to go back! Ugh
sunseeker56 is offline   Reply With Quote
Old 07-13-2018, 06:19 PM   #9
bobgeri's Avatar
We had a ton of problems on our first coast to coast. Dennis Dillon RV in LA got us all fixed back up and under warranty. This trip has been flawless so far. Our slide housing leaked water into the compartment while driving in a snowstorm. The water shorted the Murphy bed controller breaking the drive into pieces, water heater igniter wire shorted out on the door every time you closed it, and two slide motors broke. Then the whole Convection oven/ microwave and cabinet fell off the wall in downtown Wash DC. We got partially fixed by Camping World in Marion NC but we lifted that bed in and out of that well every single night for almost a month. So far this trip itís been great.
2016 Coachmen Prism 24M
bobgeri is offline   Reply With Quote
Old 07-13-2018, 07:00 PM   #10
You are a patient man
With those kinds of issues on a new motorhome, I would have sold it back to the dealer.
I guess I'm spoiled by Japanese quality vehicles. Yes I know, these are rolling houses and there is no comparison. It's still not acceptable.
solera
