Old 07-28-2016, 03:52 PM   #11
hkreck's Avatar
Interesting I got mine through Eurocamper and installed myself, Mine are installed the same as what Brian in showing.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 07-28-2016, 04:08 PM   #12
Originally Posted by hfalbright View Post
Personally, I would just splice a piece into the wire and make it work. I have a Solera and the wiring is long enough but there is a little yellow connector that was unsecured and got separated from the motion of rotating the seat. I found a suitable spot to secure it with a nylon cable tie so that it will not get pulled apart when the seats are rotated. Problem solved.
X2
a couple pieces of wire, four barrel splices and your back in business
ShermanD is offline   Reply With Quote
Old 09-09-2016, 09:51 PM   #13
Ecopco's Avatar
This happened with our Solera. MB said that when the swivel seats are installed they are supposed to use a longer wire to the seat belt fastener. When this wire gets cut (from swiveling the seat) the airbag light goes on. Mercedes ordered a new seat belt buckle and wire and repaired the issue. It cost about $350 and FR reimbursed it since we got approval from their warranty department. The dealership told us that they see this all the time.
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 09-09-2016, 09:55 PM   #14
GM
bclemens's Avatar
The sad part is, those swivel seats come from Mercedes. So if a longer wire is supposed to be used, then it is MERCEDES that should be paying for it.
That is not an aftermarket add on...those are stock seats.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 09-09-2016, 10:03 PM   #15
Ecopco's Avatar
Seat belt wire harness breaks when seat turned
Agreed. Customer is put in the middle. I give FR a lot of credit for standing behind the product even thought it wasn't their fault.
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
