Originally Posted by CharSolera
Steve, there is a gas strut on the bottom edge. Wind puts a great deal of strain on the attachment points. I'm looking for something which would prevent the strain on the attachment points.
I had the strut anchor pull out of the coach frame step. It was also bent from the force. I straightened it and added two more screws. The door will still strike the awning arm if it is extended, so like the OP mentioned, I use foam (in my case, a piece of swimming pool noodle) to protect both the door and awning. I don't see any way to attach a chain stop like a house would have on a storm door.
I've found the biggest risk of the door getting "out of control" is when exiting the coach, since you must navigate the deep step well and hang onto to the door's flip latch as you completely exit. There is not a good hand hold on the door! That door can get away from you fast in the wind!
The only thing I have thought of that might work well is to attach a cord or strap near the latch to use as a tether when opening the door. It could hang between the door and the screen when not in use, and be pulled through the slide opening of the screen door when needed.
I'll look over my door and see if there is a good attachment point. I'd probably cut a 3' or so piece from one of my nylon cinch straps to use for a tether. If it works, I'll post a pic.
