06-14-2018, 11:07 AM
Setting up for towing our Jeep
New to our motorhome We have now had about 6 months. Towed a Travel Trailer for the last 8 years. My Wife and I have the 2018 Forester MBS 2401 (it appears we were in the first of the 2018 series Coach body and the end run of the 2016 manufacture of the 2017 Mercedes chassis. We are wanting to tow our 2012 2 door wrangler jeep (automatic 4wd) and are asking for some advise and direction of others experiences regarding the tow Set up.
Being new to this type of towing my research has presented me with several options unless others have a thought.
1) The Roadmaster line with the Roadmaster nighthawk tow bar, the roadster invisibrake, and a baseplate
2) the Ready brute elite tow bar (i understand this has an internal brake system) and of course a base plate
3) the baseplate question ---- which one would work best with the Jeep.
4) we are in the Dallas area and does anyone have experience with anyone local that they recommend to do this install. We want to ensure the Lights and brake and over all level of the tow is correctly completed.
Any advise is greatly appreciated
Cheers,
Mike and Brenda
06-14-2018, 12:32 PM
Motorhome magazine publishes a guide to dinghy towing once a year and the guides are available online here: Downloadable Dinghy Guides | MotorHome Magazine
I think their guides provide a pretty broad cross section of available bits and pieces.
Generally speaking, you would like your baseplate and towbar to come from the same manufacturer. Some are cross compatible, and some can be adapted, but it's usually easier to go with items that are already matched.
Braking systems (unless they're surge brakes incorporated into the towbar) and light adapters aren't particularly specific - you can mix and match as you like.
Since your dinghy already has a few years on it, it's likely that all of the manufacturers will have a baseplate that matches.
As for installation of all this stuff ... that's a bit of a - ahem - crapshoot. RV dealers will usually do the job, but it may not really be their area of expertise. Trailer supply places and machine shops also sometimes do this type of work but, again, it's not in their usual routine. If you can arrange your time and trips, I highly recommend going directly to the baseplate and/or brake system manufacturer to get your bits installed - it is what they do and they're a lot less likely to screw it up. (Don't ask me how I know that...) Failing that, I'd ask some questions about how many baseplates/brakes a dealer (and the specific technician) have actually installed. And whether they've worked on your type of vehicle.
The last time I did this I went with a Blue Ox baseplate, towbar, and light kit (installed at Blue Ox in Nebraska) and an SMI Stay'N"Play Duo braking system (which was not installed at SMI ... and didn't work well until after a couple of visits to SMI...)
Dave
2015 Solera 24R
2014 Mercedes Chassis
06-15-2018, 10:23 AM
Originally Posted by mriddle97
New to our motorhome My Wife and I have the 2018 Forester MBS 2401 We are wanting to tow our 2012 2 door wrangler jeep (automatic 4wd) and are asking for some advise and direction of others experiences regarding the tow Set up.
Cheers,
Mike and Brenda
Ready Brute is made by NSA Products. I use their "Ready Brake" product in conjunction with a Demco bar and plate on my Wrangler.
It's the only mechanical surge brake system that I am aware of that is legal in all of North America when used in conjunction with the optional break-away unit.
I chose it over other options because it is simple and there is virtually no way it can fail. No electronics, no battery, nothing to position inside the towed vehicle and nothing to stow when not in use.
A Wrangler is the easiest vehicle for an install. I did my own, but I have some mechanical skill.
I've used it several years now and it performs as advertised. Be advised that it has to be set up properly. I saw someone recently using the Brute but the brake cable was not taut. If there is slack in the cable it won't work!
Mark, Susan and Barney the SheltiePoo
2016 Forester MBS 2401WS
Wrangler Toad with NSA Ready Brake
06-15-2018, 12:00 PM
Our set up for towing 2017 wrangler jk:
Readybrute elite with blue ox clevises
Ready stop breakaway
Currie base plate
Cooltek wiring harness.
I agree with Mark, system works great, proportional and very reliable once cable length set up. No need to worry about battery or actuator electronics.
All base plates are probably fine, I chose the Currie plate for aesthetics's. looks like a skid plate. Good luck
2015 Solera 24r
2017 Jeep Wrangler
06-15-2018, 01:11 PM
We have the 2017 MBS Sprinter and tow a 2008 Jeep JK Sahara. We use the NSA Ready Brake and Breakaway system (wife and I installed these ourselves)) and use a Blue Ox baseplate (was installed on the jeep when bought used along with wiring for lights). We have towed across the western US with this and no issues. Just came back from the Oregon coast yesterday and pulled over several passes and curvy roads with the wind blowing hard and no issues. Highly recommend the NSA system - lifetime warranty, simple, no electronics and very reasonably priced (we bought from Amazon).
Different question for you - when you registered your MH, was it registered as a 2018 or 2017 model year? I am in Oregon and when we purchased our 2017 (on a 2016 chassis), DMV used the chassis vin and set it as a 2016 model year. After several months of back and forth - finally got it changed to the 2017 year on registration. Just something to watch for on your end as it's not fun to take a 1 year hit on value as soon as you register it.
2017 Forest River SunSeeker
Mercedes Diesel 3.0 L
Sprinter Chassis
06-15-2018, 01:18 PM
Check out the BlueOx Autostop, same thing basically.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
06-15-2018, 02:17 PM
I also use the Ready Brake and installed it myself. It does take some mechanical ability to install, very tight quarters under the JK Jeeps. I have a Blue Ox Tow Bar and Base Plate. Have towed over 20K miles with no problems.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Jake & Casey
USN-RET/DOD-RET
06-15-2018, 08:03 PM
X2, but towing Smart car.
2014 Solera 24R
USN Retired
06-15-2018, 09:46 PM
I recently installed the base plate and wiring kit with brake relay on my 2016 Jeep Wrangler with the aid of my son-in-law and videos from eTrailer. The videos were very detailed, step by step, and extremely helpful.
I believe most people can do this if they watch the videos many times and acquire the proper tools. Having an extra person as a guide or assistant is helpful as well.
Kelly & Sara Sandifer
New Braunfels, Texas
2017 Georgetown GT3 30X3
Harley Davidson Trike & Hobie Mirage Outback Kayaks
7x14 Covered Trailer (for Harley and Kayaks)
2016 Jeep Wranger (Toad when not on HD or Kayaking)
06-16-2018, 09:36 AM
Currie base plate
My Jeep is an '04 TJ. The Demco plate for the TJ has a forward facing hole exactly in the middle of it that was perfect for the terminus of the sheathing for the brake cable. Being able to use that hole to anchor the end of the cable saved me a lot of install time.
