Old 06-24-2018, 06:45 AM   #1
GeoDoc's Avatar
Should I Change the Oil
Just got a 2106 Prism with less than 3000 miles since new. Mercedes Sprinter.
Should I change the oil?
Ron & Peggy
Punta Gorda, FL
2016 Prism 24M
2004 Bluebird M380 (sold)
GeoDoc is offline   Reply With Quote
Old 06-24-2018, 06:51 AM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
I would, only 3000 miles, but been in there 2 years.
Fresh start!
Ida Ratherbe Camping is offline   Reply With Quote
Old 06-24-2018, 06:52 AM   #3
cavie's Avatar
And your manual says?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-24-2018, 07:36 AM   #4
GeoDoc's Avatar
I'll probably do it anyway. Manual is vague on time.
We have a Mercedes Dealer close by that is on the list of Sprinter Service Centers.
I have heard that service for Sprinters is expensive. I wonder how much a simple oil and filter change would cost?
Ron & Peggy
Punta Gorda, FL
2016 Prism 24M
Old 06-24-2018, 07:52 AM   #5
B and B's Avatar
Depending on filter set, if fuel filter is required and oil type I would budget at least $250.00 for a initial service.
Old 06-24-2018, 09:42 AM   #6
AudiDudi's Avatar
<snip>
I did my own oil change and the parts were ~$92 for the oil and filter. Very easy to do and you don't even have to jack up the motor home. Napa puts the oil on sale for $5.79/qt occasionally.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 06-24-2018, 10:58 AM   #7
GeoDoc's Avatar
Although the manual says it will tell you when to do it, I am going to do it anyway. I think it says somewhere else 15,000 miles.
We are going on an extended trip in a couple of weeks so I want a base line for my ownership. I especially want a fuel filter change and that is a pricey little item. $55 to $75 according to parts houses.
My single engine boat's recent annual service was over a grand so this MB deal is not much if it will last 15,000 miles.
Ron & Peggy
Punta Gorda, FL
2016 Prism 24M
Old 06-24-2018, 11:04 AM   #8
KRedburn's Avatar
Just an opinion --- If I were to purchase any used vehicle, I would change out ALL fluids in order to set a baseline of service.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 06-24-2018, 11:11 AM   #9
GeoDoc's Avatar
I agree on oil and fuel filters because they are exposed to the outside environment...especially changes in humidity.
What else should I change?
Coolant can be tested for effectiveness and gear oils are sealed.
What am I missing?
Ron & Peggy
Punta Gorda, FL
2016 Prism 24M
Old 06-24-2018, 11:26 AM   #10
Many tribologists recommend an oil change every 12 months regardless of mileage and I follow this advice.
At 2 year mark, I would replace brake fluid (something I do on all vehicles), coolant, and possibly power steering fluid. Since I've been doing fluid replacements every 2 years, I've never had a power steering rack leak, never a radiator coolant leak, or needed to replace and/or overhaul brake calipers.
Skyliner is offline   Reply With Quote
