Old 01-07-2016, 07:27 AM   #21
khocke's Avatar
(hijack warning: more Side Door content)
On the sticking Side Door issue: in addition to aligning the strike plate by loosening those 2 phillips-head screws, my screen door latch wasn't fully retracted when clipped to the side door. I needed to realign the black plastic screen door latch clip that's attached to the door by redrilling the 2 mounting screws a bit lower. NOW my side door opens super smoothly.
2015 Sunseeker MBS 2400R
khocke is offline   Reply With Quote
Old 01-07-2016, 07:34 AM   #22
Left Coast
For no harder than it is, don't know why other folks won't take the time to look at this stuff.....
Old 01-07-2016, 09:04 AM   #23
Do you mean an alternative style of exterior slam latch?
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
Old 01-07-2016, 09:07 AM   #24
Left Coast
Yep
Old 01-08-2016, 05:18 PM   #25
Well PLEASE share that part number when you decide. These have got to go.
2014 Honda CRV
Old 01-08-2016, 05:54 PM   #26
Left Coast
Trailer Parts Superstore.......1-800-453-7379.....Part # 317649....{ippert brand, mfg. by Southco....$42.88 each
Old 01-08-2016, 08:27 PM   #27
Farkasb's Avatar
Thanks! Can't tell by the description are they metal or plastic? When you installed / replaced did they fit in the existing hole without cutting or modifying the door?
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 01-08-2016, 08:29 PM   #28
Left Coast
When 'ya all ask questions, hit the 'quote' button so a person knows who the question was intended for....
Old 01-08-2016, 08:31 PM   #29
Left Coast
Metal....Direct replacement for those of you that already have'em....I didn't. I cut my own holes for the install
Old 01-08-2016, 08:48 PM   #30
Blackhat6mike's Avatar
Originally Posted by CaptnJohn View Post
There are quite a few products. I have been using Dry Lock a product of 3 in One the oil company. What ends up inside the lock is always a fine dry powder and it lubricates along with prevents corrosion inside.
I agree on the Dry Lock or Dry Slide products to lube locks as WD-40 turns to gum over time that will make tumblers stick. Then you will need a spray solvent sprayed into it to clean out the goo. I believe you will be hard pressed to find a locksmith that recommends WD-40. I've asked before.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
storage
