Old 01-24-2016, 08:03 PM   #1
Petersb's Avatar
Slide out
What,s the best to use for slide out seals
Petersb is offline   Reply With Quote
Old 01-24-2016, 08:11 PM   #2
trbomax's Avatar
I'll go against what everyone here will tell you and say nothing. Of the people I know,none of them use anything. My bil's cardinal was 15 yrs old when it burned to the pavement last year,he never used anything and never had leaks. My son's Wildwood is going on 4 yrs old,nothing.Last summer I ask around in campgrounds and never found anyone that used anything. just sayin'...............
trbomax is offline   Reply With Quote
Old 01-24-2016, 08:53 PM   #3
I just use a silicone seal spray. I tried the "use nothing" approach and the seals stuck. It came loose but pulled some of the skin loose with it. I use the spray now.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 20 days (so far)
elchilero53 is online now   Reply With Quote
Old 01-25-2016, 09:01 AM   #4
We've been using Aerospace 303 on last 3 campers. It has a UV protectant.
Old 01-25-2016, 04:52 PM   #5
Left Coast
X2
Old 01-25-2016, 05:05 PM   #6
northstar1960's Avatar
liquid wrench makes a slide out seal spray .
northstar1960 is offline   Reply With Quote
Old 01-26-2016, 07:18 AM   #7
Just thought I mention on a side note, that I have checked the slide bolts on the "S" and they needed to be tightened. So, give that a look on your Spring check list.
Old 01-26-2016, 10:09 AM   #8
Sandiegodoug's Avatar
Can you please post a picture of which bolts were loose, we have a "s"
Never tightened any bolts
Sandiegodoug is offline   Reply With Quote
Old 01-26-2016, 03:46 PM   #9
Sorry, been put away for winter cpl months ago. But, when you open the slide there are two structural steel arms that carry the slide out. When you get a look under it you will see several bolt connections. The bolts are easily accessible and just put a socket on them to check for tightness. Discovered some of mine needed tightening. Good idea to use dry lube on the friction points while your under there as well.
Old 01-26-2016, 04:15 PM   #10
Platokidd's Avatar
X3 great stuff and use it in several other places
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
slide, slide out
