Old 10-15-2018, 08:33 PM   #41
You are correct, it is 2 screws each side of the roller. The roller is 4.5 inches long and 2 inches high. I am trying to get a new roller to install along with a 8 inch wide piece of stainless steel. I will also be "jimmying" the other rollers so they equally distribute the weight of the slide.
Charlie3254 is offline   Reply With Quote
Old 02-06-2024, 07:24 PM   #42
what tool did you use to drill holes?
delgador is offline   Reply With Quote
Old 02-06-2024, 08:28 PM   #43
Caution if adding additional rollers on 2400WS
Need to watch out when adding additional rollers since the bottom of the slide only has plywood where the current rollers are located, the other areas only have foam. I found this out when I had water damage on the bottom and had repair accomplished. I have the factory
prints if needed.
2018 2400W
Dualclassic is offline   Reply With Quote
slide
