Old 10-24-2016, 08:00 PM   #1
raptor's Avatar
Small portable heater
Is it a good idea to run a small portable heater inside MH in winter to keep moisture down? Right now I have a few moisture absorbents and not sure it's good enough?
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 10-25-2016, 12:35 AM   #2
Always Learning
If you're going to run anything, run a dehumidifier.
Old 10-25-2016, 01:16 AM   #3
raptor's Avatar
That's a good idea because I was kind of worry about heat in there when no one around.
raptor
America is great
Old 10-25-2016, 06:50 AM   #4
You can't run a compressor based dehumidifier below something like 40 degrees F, the water will freeze on the coils and the whole things degrades rapidly. Some do have defrost cycles and you will find that it is defrosting 90 percent of the time. If it worked, how would the "water" drain out of the tank when it is below freezing?
They do have desiccant based units that do not use compressors, but I am sure they don't continue to work below freezing...where would the water go?
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-25-2016, 07:32 AM   #5
BamaBob's Avatar
It is a good idea if you want to keep your rig ready to hit the road (or hate winterizing).
We did this in our 5th wheel for 3 winters, Worked great! Here is the heater we used:
https://www.amazon.com/DeLonghi-EW77...l+space+heater
We put it in the central area, turned on the "Freeze warning" (the heater keeps the ambient temp at 40°) - no issues and we had a couple inches of snow and temps in the teens & 20's for 10-14 days in a row.
X2 but instead of a electric dehumidifier, suggest you use this:
https://www.amazon.com/Improved-Eva-...rds=evadry+500
Best dehumidifier ever! And no mess and goo like DampRid. Renewable, just plug in to a extension cord and set in a open area for @ 4 hours and it is ready to go again. We currently have 4 of them in our Coach.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-25-2016, 08:05 AM   #6
Flybob's Avatar
I use a small standard dehumidifier when temps are above 40. I got one that has the ability to have a drain hose attached. I ran a 1/2" clear drain hose through the pedestal and then out the enclosed bottom of the TT. Works wonderful and is maintenance free. I tried the solid state small ones and although it is a great idea on a good day ( hot humid summer day) it might take out 1/3 cup of water which is not sufficient.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-25-2016, 08:12 AM   #7
ben31's Avatar
BamaBob, I don't doubt you like the EvaDry units. Have you ever measured the humidity before and after use? How long does it take to reduce the humidity, and by how much?I've seen quite a few reviews of people who love their dehumidifiers, but don't really know if or how well they actually work. I'd like some test results. One person I asked (who loved another dehumidifier) only saw a 5% change in the humidity levels while using it. A 5% change can be caused by the interior heating up, etc. so the dehumidifier didn't really work. Yeah, it filled up the small reservoir over the course of a day, but it really didn't seem to impact the environment.
Sorry for the side conversation.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 10-25-2016, 05:45 PM   #8
raptor's Avatar
Now I may have to buy both. Thanks Bob
raptor
America is great
heater
