Old 03-10-2019, 03:02 PM   #1
Small water leak at slide
I started getting a slight water deposit at the inside of the dining slide on my 24R. I looked at all the rubber seals and they seemed fine. There was no water on the walls or ceiling. No condensation. And it was small, even in a downpour just a little puddle (2 oz).
I was passing through Coos Bay Oregon on our way up the west coast and stopped at Porter RV for a few supplies. I asked if I could borrow a ladder to check the roof. Evan (3rd generation owner) said I wouldn't be allowed due to insurance, but he would take a look. A tech came out as well. They found a couple of small potential gaps in the dicor sealant near the location, but then the tech said he's seen some slides where the schwintech rails weren't caulked at the outer edges. And when I rolled out the slide, that was apparent. Very little dicor sealant, and it had lifted. 5 minute fix! No more leak!
Thought you might like to know...Click image for larger version
ID:	198456Click image for larger version
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 04-05-2019, 11:59 PM   #2
MNtraveler's Avatar
Thanks for the info. But...where did you seal it? The vertical gap or along the horizontal rail, or both?
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 04-11-2019, 09:06 PM   #3
The horizontal gap along the top of the schwintek rail. Clean it first with mineral spirits to make sure of good adhesion.
Eric Jackson
2015 Solera 24R
Old 04-11-2019, 11:27 PM   #4
Thank. I will have to remember to check these. Almost time to open up the slides and begin preparations.
AbdRahim is offline   Reply With Quote
leak, slide, water, water leak
