Old 10-17-2017, 08:49 AM   #1
Sandiegodoug's Avatar
Solar system on isata 3
Just wondering if itís possible to add a couple more panels to solar system without changing out controller. We do a lot of beach dry camping.
Sandiegodoug is offline   Reply With Quote
Old 10-17-2017, 08:51 AM   #2
Flybob's Avatar
What is the current capacity of the controller?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-17-2017, 08:55 AM   #3
Think 30a, donít have unit yet
On my current solera, I measured each panel and it measured 20 volts and 4.5 amps. Iím not an ee
but maybe system could handle 2-3 more panels?
Old 10-17-2017, 10:14 AM   #4
Your problem may be where to mount them.
If placed on an extension cord to get into the sun , use at least #10 wire for the cable to max the volts/amps into your charging system.
A method of keeping them from talking a walk might be wise.
FFred is offline   Reply With Quote
Old 10-17-2017, 11:55 AM   #5
Rich.M's Avatar
We have 4 100 watt panels on 30 amp controller. Amps top out at 24 amp in full sun. I wouldn't go higher without changing the controller.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 10-17-2017, 11:57 AM   #6
Thatís what I wanted to know
Old 10-17-2017, 01:24 PM   #7
MilCop4523's Avatar
I JUST PURCHASED A 500w 30 AMP SOLAR CHARGE CONTROLLER AT HARBOUR FREIGHT. HAVE TO FIGURE OUT WHERE TO SPLICE THE DRN THING INTO THE LINE FOR IT TO WORK THOUGH. OP DO YOU HAVE A PIC OF WHERE YOU MOUNTED YOUR CONTROLLER?
SORRY FOR CAPS LOCK - MY KEYBOARD DIED
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 10-17-2017, 02:50 PM   #8
Rich.M's Avatar
The safest plan would be to run 6 gauge from the controller directly to the batteries on a separate line if you are planning to set up 400-500 watts solar. The gauge for theline from the roof will depend on if you run series or parallel on the panels. Wire routing and mounting will vary by model. You may want to post that question in the forum for your rig.
2015 Solera 24r
2017 Jeep Wrangler
Old 10-17-2017, 02:51 PM   #9
WolfWhistle's Avatar
OP doesn't say many 100w (I assume) panels there now. 30A Trimettic can handle up to / about 500w of array and can limit amps if on rare occasion current exceeds 30a. Not all controllers are equal. If panels have same voltages you can add when wired in parallel.
Controller can go anywhere between panels and batteries. But I would size wire for no more than 3% voltage drop. Get volts and amps from panel tag.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 10-17-2017, 02:53 PM   #10
Thatís what I did on solera
Line from roof to controller
Controller to batteries
I hid mine in the lower drawer under the sink(wife said no cutting)
New one installed by dynamax by stairs
solar
