Old 08-01-2018, 01:56 PM   #1
Solera 2011
Problem with leak in overhead bunk area. Water under the plywood the mattress rests on. Any suggestions on where to check for leak or anyone with similar issues ?
fredhartman is offline   Reply With Quote
Old 08-01-2018, 04:36 PM   #2
2012 Solera
Two most commonly mentioned causes for leaks in that area that I’ve seen on the forum are the seam between the roof and the front cap (many recommend covering with eternabond tape) and the clearance lights (re-caulk).
FYI
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 08-09-2018, 08:20 PM   #3
One other place of potential leak is around the windows in the bunk. But generally this leak is frommpoor installation, and unlikely your source, after owning for several years.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
2011, solera
