Old 06-24-2018, 07:14 PM   #1
Phinias's Avatar
Solera 2015 24 R water from air-condition vents over head
Any ideas or experience
Phinias is offline   Reply With Quote
Old 06-24-2018, 09:11 PM   #2
I'm going to guess the condensate drain line is plugged. I've had that happen on cars before and wound up with water on the floor.
Likely an accumulation of dirt/debris in the drain on the unit. I used a wire to ream out the tube on my cars. I imagine you will need to view a diagram of your model to locate the drain (unless it is readily apparent) and clean it either with a wire or compressed air.
Mark & Susan
2016 Forester MBS 2401WS
Wrangler Toad
barnbnb is offline   Reply With Quote
Old 06-25-2018, 06:43 AM   #3
Phinias's Avatar
Sounds about right.
Thank you for your response
Old 06-25-2018, 06:47 AM   #4
cavie's Avatar
Originally Posted by Phinias View Post
Sounds about right.
Go up on the roof and pull the cover off.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-25-2018, 06:54 AM   #5
Phinias's Avatar
Last time up, I fell off and broke my arm. I think I'll take it to an RV show (high price of growing old)
solera, vent, water
