Update on the leak. I took it in this morning prepared to leave it for several days. The suspected oil leak in the 'valley' is a gasket on the oil cooler. Apparently they are on version 4 of this particular gasket. However, I got a call late this afternoon and the actual problem was a bad oil cooler fitting at the transmission. An easy fix and the rig is done already! The second one they had seen, both on motorhomes.
2017 Isata 3 24FW
2004 Jeep Wrangler
