Old 06-20-2016, 05:52 AM   #11
How about a Scan Gauge?
Originally Posted by backdoctor View Post
MB cleared the codes and it started right up. Hasnt happened again, but every time I start the rig, I wonder? Will it start? DW doesnt want to let our kids use it for fear of them getting stuck somewhere. We've had numerous issues with NOX sensors (replaced twice) and fail to start once. But I'm optimistic that we're past those issues. Fingers crossed, knock on wood, rolling eyes....
If clearing the codes was all it took to get your MBS started again, this might be a good motivation to install a Scan Gauge or other OBD II code-reading/clearing device. Besides providing important engine/chassis info - would it not be able to defeat limp mode for some codes? Just a thought.
KatanaPilot is offline   Reply With Quote
Old 06-20-2016, 12:54 PM   #12
I'm not sure the scan guage would clear the MB propietary codes. I will likely purchase one anyway, but whether it would solve this problem is uncertain.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 06-25-2016, 05:44 PM   #13
An update on my non starting problem. It seems they told me I was missing fuses 5 and 6. That's what their computer said, then they put them in and it started. Did you pull those fuses out? they said. No I said. I've been driving it for almost two months and it started every time. It's a mystery. I pick it up Monday. The taillights still don't work right though.
captdanerie is offline   Reply With Quote
Old 06-27-2016, 06:59 PM   #14
An update on the starting problems. It definitely was one or both of those fuses! Everything is running fine now. Maybe I moved fuse 5 when I was trying to turn off the tail lights because the Kurt controller got wet. But even the taillights work fine now because it really hasn't rained for a month.. I need to protect the controller.
Old 06-29-2016, 09:54 AM   #15
All of my intermittent "won't start" problems are gone since having the starter replaced under extended warranty. Dealer never did experience the problem as it would only occur after sitting for several days to weeks. Kept a log and video recorded the start attempt each time. Finally captured a no start with audio and full view if the dash lights.
Tech finally agreed and it was written up as a starter problem, which extended warranty then helped with.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
