Old 08-07-2017, 10:58 AM   #1
Mikegjax's Avatar
Step
The main pivot bolt on the entry step broke at the thread to shoulder positon. Was able to order replacement from Lippert. I will let you know how the easyout of the threaded part goes.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-08-2017, 10:26 PM   #2
Been there, done that. Twice.
Hardest part is remounting the steps single handed.
Used 2x4s, a dolly and a jack
https://goo.gl/photos/Sovqt3fnwcVwwdAX8
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 08-12-2017, 03:49 PM   #3
Mikegjax's Avatar
Finished replacement of the broken pivot bolt. The treaded end of the bolt is tack welded to the bolt receiver. A little die grinding took care of that. Some penetrating oil and easy out took care of getting the bolt end removed. Used a small floor jack to support the step for removal and installation. All in all not a bad job, just takes a little time.
The bolts I ordered from Lippert were exactly the same as original.
2014 Solera 24R
USN Retired
