Old 10-29-2017, 11:46 PM   #1
Petersb's Avatar
Thinking out loud
Is it nessary to by pass my hot water tank I blow out all my water lines and put antifreeze in the p traps and toilet and shower.
Petersb is offline   Reply With Quote
Old 10-30-2017, 12:02 AM   #2
Just as confused as you
Scrapper's Avatar
Do you drain the water heater by removing the anode rod (Suburban) or drain plug (Atwood)?
How are you getting antifreeze into the toilet flush valve?
They have a tendency of having water still in them when you blow them out. It doesn't take much water for the valve to freeze and crack.
Do you remove the water filter and dump the water out of it?
No matter how much air you blow through the filter you will never empty all the water out of the canister unless you dump it.
Do you use your freshwater tank?
If you do then there is still water in the screen filter and water pump.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
