Old 09-21-2016, 08:48 PM   #11
Originally Posted by Skialberts View Post
Just got our 2017 Forester MBS 2401R. I've seen other posts about tire pressure, but no definitive answer. The tags on the door frame say 61lbs, the tires have 80 lbs on them. Which one is it? We have taken 1 short trip so far and weighed in about 50 lbs overweight. Anything we should be worried about?
In your case the door sticker should not be your guiding reference. Simple rule, knowing you're at max weight limit, run your tire pressure at or very near your tires recommendated inflation pressure. One unkown you are presented with is your individual axle weights, so you will need to monitor tire wear closely until you dial that in. Or, get it weighed (by axle ) when you're typically at loaded weight, and adjust pressures within the tire recommendations accordingly .
Old 09-21-2016, 09:07 PM   #12
GreenImp's Avatar
Send a message via MSN to GreenImp
Originally Posted by DaveJordan View Post
Since there are differing opinions, you won't find a definitive answer.
Lower tire pressures worry some drivers as they're more likely to be driving on under-inflated tires and their fuel mileage may be lower.
Higher tire pressures worry other drivers because the tires may wear prematurely and the ride may be harsher.
All in all, you can run them at 61 psi, at 80 psi, or anywhere in between (I run at 70...). Just don't venture outside of the 61-80 range and you'll be fine.
Dave
I realize the OP has accepted an answer already but I want to say that I have written a few similar responses as Dave's to similar questions as the OP's, but I have never worded it so well as Dave just has.
In my opinion...
+1
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-22-2016, 01:36 AM   #13
dukeboone's Avatar
I run mine at 65psi and the pressure seems to max out at about 80-85psi according to the TPMS with maximum temps so far pushing towards 110.
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 09-22-2016, 04:37 AM   #14
ilmor's Avatar
When I had my Solera (MBS chassis) according to the sticker the recc. pressure was 65 all around. After researching a little bit, looking at the tire charts, taking into account what the actual weight of the motorhome actually was, w/ cargo and passengers, I determined that 65 was unsafe and ran no less than 73 or 74.
Also consider that my new Sunseeker, similar size to my Solera (shorter, same height, wider) , but with essentially the same tires, recommends 80 rears and 75 front. Then again, it will tow up to 10,000 lbs...
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 12-15-2016, 05:45 AM   #15
The time to look at tire pressure is after a long hard run at speed.
Look at , just to see if the sidewall max tire pressure is surpassed.
Most tire mfg have a web site that will give initial cold tire pressures for specific tire loading. These take into account the pressure rise with highway travel.
FMCA and other folks can weigh the 4 wheels individually of your RV to find out if there is any overloading.
FFred is offline   Reply With Quote
Old 12-15-2016, 07:21 AM   #16
Well...no.
As explained at tirerack.com, here:
Tire Tech Information - Tire Specs Explained: Maximum Inflation Pressure
the maximum pressure rating for a tire is the maximum cold pressure. Tires are designed to handle hot, in use, pressures considerably higher than the rated pressure embossed on the side of the tire.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 12-15-2016, 11:36 AM   #17
GreenImp's Avatar
Yes, tire pressures should always be set COLD. In fact many tires even use the word cold right on the sidewall rating.
Old 12-15-2016, 11:27 PM   #18
Airdale's Avatar
The correct pressure is 61 PSI cold. Never use less than that. If you have to go higher you're probably over weight.
The tire pressure indicated on the tire sidewall is the maximum permissible by it's manufacturer for that tire whatever size or brand.
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 12-16-2016, 05:12 PM   #19
I don't care what air pressure the door sticker says. I set air pressure COLD according to my gross weight and tire rating.
I suspect that in Skielberts case the 61# may have been MAX for a smaller tire.
It could also be based on the vehicle gross weight and the current tire (Less load range).
Marvin
GA_Boy is offline   Reply With Quote
Old 12-17-2016, 10:34 AM   #20
Airdale's Avatar
Marvin
The safety standard you follow is from the trucking industry safety standards found in FMCSA regulations. They do not require a recommended cold inflation pressure. Their minimum is based on load carried. That standard does not provide any load capacity reserves whatsoever. It is also not in compliance with the FMVSS standards our RV trailers and almost all of the vehicles used to tow them were built to follow.
Motorized RVs are built to the standards found in FMVSS regulations.
USN - RET
DOD - RET
SSA - RET
pressure, tire
