Old 06-19-2019, 10:36 AM   #1
AudiDudi's Avatar
Tire wear
2016 Prism 24G with 14.5k miles. I'm seeing outside edge tire wear (have to replace the tire!) on the passenger side front. Driver's side is OK. I had the alignment checked about a year ago and it was in spec. Tire pressures are checked on a regular basis and pressure is good. It seems most of the wear happened in the last 1500 miles.
Any thoughts as to what to look for?
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 06-19-2019, 10:49 AM   #2
wmtire's Avatar
Alignment is the first thing to check....and see if there is any mechanical issues causing the misalignment.
One pothole can do it.
https://blog.firestonecompleteautoca...-and-vehicles/
https://www.morrisonautomotivesc.com...ignment-causes
2011 Flagstaff 831 RLBSS
Did you know, according to Google: Pepsi was once the 6th largest military in the world?
Old 06-19-2019, 10:51 AM   #3
Outside edge wear can be caused by several things. Excessive Camber is one that comes to mind first and often. If it's on the passenger side it could also be caused by "Cornering".
Believe it or not, in this country where we drive on the RH side of the road and the steering wheel is mounted on the left, we tend to be more agressive when turning left. Our seat is right there in the corner and we can see everything real well so we aren't as timid as when cornering to the right. This is just one factor.
Second is road crown. It tends to push a vehicle to the right so it's necessary to steer slightly to the left. This puts the right steering tire in a constant yet slight left turn. This puts more load on the outside edge of the passenger tire.
Last item is suspension geometry. Independent suspension changes geometry with every bump. Camber changes as well as toe angle. Depending on the position of steering arm in relation to the inner pivot on the tie rod, every bump can cause the tire to toe in. Can also be influenced by a change in load in the vehicle. Any shift of load from when it was aligned can make big changes in this behavior depending on how much and which way it was shifted.
Depending on the severity of the wear one might just regularly exchange positions of the tire from left to right until both are worn and then see if replacement exhibits the same wear. Sometimes it's just the tire.
OR----
Have the alignment checked again and do so with the vehicle loaded exactly as you travel most of the time (Water tank full or partially empty, cargo stowed the same, bathtub filled with canned goods, or whatever).
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-20-2019, 06:15 AM   #4
If the alignment is ok ,just rotate the tires to share the wear.
This should get you to the usual 8 years where tires are usually discarded.
FFred is offline   Reply With Quote
Old 06-20-2019, 01:22 PM   #5
2012 Solera
I switched to a different alignment shop after I experienced front tire edge wear after my first alignment. No edge wear since the second alignment. First shop was “old school” - second was computer alignment.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 06-20-2019, 01:43 PM   #6
AudiDudi's Avatar
Good to know! Thanks.
Mike and JoAnne
tire
