Old 06-03-2016, 10:02 AM   #1
tireminder install
I have 2016 MBS2400WS and have just purchased the tireminder system...I can't confirm if the inside dually has a metal valve extender...it looks like bronze... anybody know what's standard? I've heard that I should replace even the rubber valve coming out of the tire with metal...opinions? any experience w/ this system appreciated. also what pressure do you all run...sticker says 61#cold...tire says 80# max...is this load related?
gp2down is offline   Reply With Quote
Old 06-03-2016, 10:09 AM   #2
Brother Les's Avatar
Call the company who sold you the tireminder, they are the best source for the information that you are asking about. they should have a customer service number to call with the product material.
Brother Les
Old 06-03-2016, 12:32 PM   #3
Pod2Vibe's Avatar
Search TPMS in this and the Solera Forum for related threads. You will find links to valve stem upgrades, as well. This is highly recommended for TPMS sensors.
Typically plastic extensions have been installed at the factory. A lot of us had issues and replaced with quality one piece stems and TPMS systems like Tire Minder, etc.
Personally, since I made the switch, no more issues with losing pressure on my inner duallies due to the less than stellar factory extensions. I have also found that 78 PSI cold seems to be my sweet spot for ride and performance. This bumps up about 10 PSI per my TPMS on really hot days like Memorial Day Weekend just provided.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 06-03-2016, 12:46 PM   #4
bob dirt's Avatar
Mine were those plastic airless extenders. The valve stems are rubber. Very hard to service. I ordered aluminum wheels and will be installing steel stems on them and the inside steel wheels. No more hassle with the crappy wheel covers for me
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 06-03-2016, 09:04 PM   #5
MNtraveler's Avatar
Use the air pressure noted on the label inside the driver's side door. It is weight related. Never just use the tire maximum - that is a maximum limit only, not a guide.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 06-04-2016, 10:35 AM   #6
Tire pressure?
I'd like to know what pressure other members use on their MBS tires. Rather than do it here, I'll start a new post.
Aspenmeadow is offline   Reply With Quote
tire
