Old 06-24-2018, 01:26 AM   #1
To tow or not to tow
We are new owners of a 2019 Dynamax Isata 3 24FW on the Mercedes Benz Sprinter chassis. We have downsized from a 40' diesel motorhome and towed a 2006 Honda CR-V "4-wheels down" that has a Gross Vehicle Weight rating of 4,450 lbs. The Sprinter came equipped with a wired 7-pin electrical plug and a 2" standard hitch but there is a discrepancy on whether or not we can tow.
""Dealer" says the Isata can tow 5,000 which should work with our existing Roadmaster All-Terrain hitch. However, we just sat down with the Sprinter Service Manager at the local Mercedes dealership where we will go for MB service and he says "ABSOLUTELY DON'T TOW". He said there is too much rear end weight from the RV portion on the chassis and there will be suspension and transmission problems if we tow the CR-V.
What have been your experiences? I have seen photos of 24' Dynamax towing Jeeps 4-down. Anyone towing CR-V?
ANY PROBLEMS???
-- "CoolJudy"
Coolrvers is offline   Reply With Quote
Old 06-24-2018, 01:35 AM   #2
You might check with MB online, I am sure they would have an advisor to answer within 48 hours.
Timtation is offline   Reply With Quote
Old 06-24-2018, 01:35 AM   #3
Bluepill's Avatar
The actual unloaded "Curb Weight" of my 2006 CRV EX AWD AT is 3472 according to Honda website here:
http://owners.honda.com/vehicles/information/2006/CR-V/specs#mid^RD7886JW
The VIN tag on the driver's door pillar states GVW at 4450 as you mention. The tire pressure label states "Do not exceed 850 Lbs. total passenger and cargo weight"
Old 06-24-2018, 02:32 AM   #4
namusmc's Avatar
ANY PROBLEMS???
-- "CoolJudy"
Welcome to the forum from Grass Valley!
I don't tow with my 2016 Forester 2401W but would not hesitate as long as I am within all weight limit specs and, most importantly, still under MB drivetrain warranty. Once out of warranty, I might rethink the idea and tow a Smart car.
Enjoy your new rig!
namusmc is offline   Reply With Quote
Old 06-24-2018, 10:31 AM   #5
chroniekon's Avatar
You may want to run this question past the guys on the Dynamax subform here. Lots of folks towing with their Isata 3's. But not 5,000 lbs. The hitch itself is rated for 5,000 lbs, but your tow vehicle should be closer to 3,500 to 4,000 depending on the options your motorhome has. The weight tag on the drivers door jam should get you close to what's allowed.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 06-24-2018, 01:01 PM   #6
ANY PROBLEMS???
-- "CoolJudy"[/QUOTE]
I can't speak to your exact model but we also downsized from a 40' DP to the MB sprinter (Solera) and continue to tow our '09 CRV with no problems. Towed nearly 10,000 miles. I love the torque.
lacamastraveler is offline   Reply With Quote
Old 06-24-2018, 01:18 PM   #7
Great to hear. ❤️. Thanks for the reply.
Yes, There really is a Cool, California
New owners: 2019 Isata 3 Series 24FW
Old 06-24-2018, 01:32 PM   #8
Senior
I have a Forester MBS 2401WS that i tow a Honda CRV with for 25,000 miles so far without any problems. I think you have been given some misinformation.
Although the Sprinter has a 5,000 lb. Hitch the maximum you can tow with it is 4,200 lbs.
Towing a car 4 down will only add half of the weight of the tow bar to the chassis and none of the weight of the car.
Since you can not have any passengers in the car when you are towing it is unlikely you would have too much weight in the car to make a problem.
The only problem I have is I live in Colorado and have to go over mountain passes to get to and from home that slows us down to 40 - 45 MPH. No big deal.
sailski is offline   Reply With Quote
Old 06-25-2018, 06:13 AM   #9
The service fellow may not understand the difference between towing a trailer , where 10%-15% of the trailer weight will be carried by the hitch, and towing 4 wheels down , where maybe 50 lbs is pressing on the ball .
Just because someone can change your oil does not mean he understands vehicles.
You will need a brake system for the towd.
Honda CRV 2010 , with brake buddy, no problems.
FFred is offline   Reply With Quote
Old 06-25-2018, 11:12 PM   #10
Sandiegodoug's Avatar
We tow a 2 door jk
No problem at all
Sandiegodoug is offline   Reply With Quote
