Old 03-03-2019, 02:39 PM   #1
Too cold to start
We have a 2017 MBS 2401W. It was warm here in Colorado yesterday. The coach started and ran fine. Today the temperature has been about 5 degrees above zero. so needless to say when I try to start it it just chugs and tries to start and then dies. I am sure that it's because it's so cold. I do not know or could not find anywhere online if there's any sort of oil pan or block heater that would already be on the engine. More than likely I will need to wait a day or two until it warms up some. Fortunately it is in front of my house for now and we're not leaving for Arizona until Wednesday. Does anybody know if there is or where there is a block heater on these engines? Or any other ideas to get it started and warmed up today?. Thank you
onlinemarketingmedia is offline   Reply With Quote
Old 03-03-2019, 02:49 PM   #2
Scoundrel
HangDiver's Avatar
If no block heater at least the heavy, dense, cold air thats socked in the front range will begin to slide off to the east on Monday and even moreso on Tuesday. High temps on the front range Monday will be in the low to mid 20Fs; will be 35F on Tuesday.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-03-2019, 04:03 PM   #3
Did you place cold weather additive for diesel fuel in the tank? If no, you probably have gelled the fuel line and tank.
https://fuelandfriction.com/weekend-...d-diesel-fuel/
l001952119 is offline   Reply With Quote
Old 03-03-2019, 04:45 PM   #4
Thanks for the quick replies. So my next question is if the fuel in in fact gelled, will it thaw enough to start if the outside temperature goes higher like into 30s and 40s in the next few days?
Old 03-03-2019, 04:59 PM   #5
The Cummins diesels are known to start in temps well below zero. My 63 MGB started in minus 8 once. No aftermarket stuff in the tanks.
A two year old vehicle not starting in +5 temps I would have thought would start. The things were designed in Germany.
I would wonder about the battery. Is there a switch to connect the house battery to the motor?
Installing a heater in a coolant line or block is usually not hard. I had one in a 77 dodge when I lived in Idaho. We saw -30 several times.
tomkatb is offline   Reply With Quote
Old 03-03-2019, 05:01 PM   #6
dieselguy's Avatar
Although the linked article in a previous reply tends to make people believe diesel gelling here in the Midwest is common … it really isn't with today's diesel and the cold weather additives that are put in since about last November. We predominately run diesels down to zero with extremely few gelling issues … now when you get in the -20 on down, the story changes. Newer diesels have pretty reliable glow plug circuits. I'd take a guess that your glow plugs or the power feeding them is at fault. Wait about 3 separate cycles for the glow plug light to go off on the dash, and then try and start it.
dieselguy is offline   Reply With Quote
Old 03-03-2019, 05:09 PM   #7
Crusadernoob's Avatar
Not familiar with your engine, most diesels now have glow plugs, most modern diesels start relatively easy, I'd make sure your batteries are charged, if they are and you need to run it and don't have a block heater run a hair dryer into the air intake while cranking, it just needs a little heat.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 03-03-2019, 05:42 PM   #8
Mikegjax's Avatar
If your generator will start, let it run and charge the chassis battery. Might help .
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-03-2019, 05:53 PM   #9
AudiDudi's Avatar
Add some Diesel 911 in the red bottle. If the fuel in the filter gel'd, the filter may need to be changed. It is supposed to be in the mid 80's in southern AZ on Wednedsay.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is online now   Reply With Quote
Old 03-04-2019, 02:42 AM   #10
2012 Solera
Discussion of this in the Sprinter forum:
https://sprinter-source.com/forum/sh...ad.php?t=37285
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
