Trials and tribulations of a Kwikee electric step....
CAUTION! LONG READ!!! But no profanity, at least on paper.
Over the winter our electric steps quit operating in the retracted posiition. I decided to wait till spring to trouble shoot it. It became an odyssey....
First thing I went to look for the folder of manuals that came with the RV. It was no where to be found. Tore the house and RV apart trying to find it. Nada. I went online and downloaded some instructions. Went to print them and my printer wouldn't work. Finally got it working and manual printed. The recommended purchasing a pigtail from Kwikee for troubleshooting purposes. NOBODY had one in stock, had to order it. A few days later and it came in, but the dealer couldn't contact me because they called the wrong area code. I called them and nobody would answer in the parts department. Called the dealer operator and she paged someone. "Yes, it's in". I drove thirty minutes one way to get it. Came home and began troubleshooting. Get inside on the drivers side and looked up. There was all my manuals. I cut the wiring to the step motor and put a solderless quick disconnect in to make my life easier in the future. I found out the motor was bad as it didn't work at all when hotwired. I ordered a new motor. It came in today. I went to install it. There's no way to remove/install the motor assembly with the step retracted so I had to get the step extended. I'm going to do this by removing the pin that connects the step mechanism to the gearbox.....six or so inches inside working through a gap about 1" wide. First I have to remove a cutter pin. I bend the legs straight the best I can, then to pull the pin out. I actually have a cutter pin tool...trouble is the handle is also about 1" thick. But I finally get it out. Now for the pin. It's normally a slip fit, EXCEPT in the retracted or extended position. It was stuck. The best prybar I had for the job was about 1 1/4" wide.... A couple beers and a lot of cussing later I finally got the pin out and the step swiveled down. Yayyyyyyy! Took a bit over an hour to get the step down. Lots of room now! I took the old motor assembly off and tested it again. Dead. I put the new motor assembly on a replaced the pin. Took maybe five minutes. I used a clevis hitch pin, instead of a cotter pin to make my life easier should I ever have to do this again. Hooked the motor wiring and went to test it. Still dead. More cussing and I start to troubleshoot again. This time I can make the steps work by hot wiring it. I left the steps in the extended position to make access easier. Well.....I'm getting somewhere. But everything checks out going through the troubleshooting procedures and it says it must be in the RV wiring. The only thing I did to the wiring was installing the quick disconnects so I replaced them. The house door is closed and the steps should retract. NOPE! All the sudden a light bulb comes on above my head! Maybe the inside switch is in the locked position! It was! Turned it off, and closed the door....
Scroll down for the conclusion....
IT RETRACTED!!!!! IT WORKED!!!!! Time for a beer.....
