Old 12-04-2015, 07:41 PM   #1
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Use of pump while connected to city water
The pressure of city water is low. Will it hurt the water pump if I turn it on?
Jeff
HomeOnWheels is offline   Reply With Quote
Old 12-04-2015, 07:57 PM   #2
Campster's Avatar
I could be wrong but the pump only sucks and pumps water from the water holding tank. i don't see how it will increase water pressure while using city water connections. In fact if your water holding tank is empty the pump would be sucking air and running dry which is probably not good for the pump itself. If you have a pressure regulator in line with your hose you might try removing it just watch out that the city water pressure doesn't rise to high for some reason.
Campster is offline   Reply With Quote
Old 12-04-2015, 08:01 PM   #3
No. It will not hurt the pump, just make sure you have water in the tank. I have had the problem at some parks low water pressure. Fine for sinks, I just turned on pump to take a shower with tank water. Remember pump draws water from tank.
drc343 is offline   Reply With Quote
Old 12-04-2015, 08:35 PM   #4
VinceU's Avatar
If shore pressure is connected and on, the pressure switch will read the shore pressure and prevent the pump from operating. If you attempt to operate the pump anyway, shore pressure will damage the suction non return valve and allow back flow into your tank. Plenty of threads on the forum about this. You can fill the tank, secure shore pressure an then use the tank and pump.
Old 12-04-2015, 08:59 PM   #5
Thanks all for the quick replies. It makes sense the pump only takes water from tank. I therefore filled it and switched on the pump. Of course I disconnected the city water.
Jeff
Old 12-04-2015, 09:43 PM   #6
AquaMan's Avatar
Not sure this is entirely true. Would depend on the input pressure from the city water line. If the city pressure is higher than what demand for the pump is, it won't run anyway. The pressure switch/backflow preventer is always subjected to city water pressure, regardless if pump is on or not.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-04-2015, 09:56 PM   #7
B and B's Avatar
X2. I use the tank water and pump all the time at Rally's to have a decent shower.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-05-2015, 06:45 AM   #8
Mikegjax's Avatar
The RV operators manual states "do not" operate the pump while connected to external water source. As long as you turn off city water, not a problem.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 12-05-2015, 07:02 AM   #9
Witch Doctor's Avatar
does that work B&B ? I always carry a rain bird pressure gage with me to check the water pressure at the site. If under 55 psi I don't use a regulator. I know that's probably a bad Idea, just in case of a spike, but in reality I have never seen it go up once it's measured but it can. My system works best at that pressure of 55 psi. Your thoughts please?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-08-2015, 07:00 AM   #10
VinceU's Avatar
Here we go again, post from today. This back flow has been going on since xxxxx was a child. Only when the pump is paralleled to shore water.
"have a 2013 Rockwood A127TH. Today, I came out to a park and hooked up the water line. About an hour later I noticed that water was flowing out from the fresh water tank inlet (located outside of the camper on the left side). I know for certain my fresh water tank was empty before arriving, but it's now full. Once I turned off the park's water line (eliminating that water pressure to the camper), the water is no longer flowing from the fresh water tank inlet, but the fresh water tank is still full. What is going on? I'm not losing water at any other point. Could this be an issue with the fresh water pump allowing water to pass from the city water line thru the pump into the fresh water tank?"
pump, water
