Old 09-17-2016, 12:42 PM   #1
Water Pump Location
Can someone please tell me where the water pump is located on the 2016 MBS 2400W? It sounds like it is under the shower pan.
Zcamping is offline   Reply With Quote
Old 09-17-2016, 05:11 PM   #2
That is where mine is. There is an access panel behind the sliding bedroom door. I have a 2250LE. But you can not remove it from there you will have to remove the entire shower surround and pan to get to it in order to replace it. I'm looking at putting in a bigger pump and thinking about coming in from the bottom by dropping the Black tank.
Did you know that the Gray water tank is only 4 inches thick and 6 feet long.....Found out while putting heaters on the tanks.
hstroupe is offline   Reply With Quote
Old 09-17-2016, 05:14 PM   #3
The access door is directly under shower door on 2400w.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 09-21-2016, 10:17 AM   #4
If anyone out there has replaced their water pump I'd love to know what model you used as a replacement. The stock pump is SO LOUD that I'd consider changing it out if the price was right. Thanks!
2016 MBS 2401w
Santos1060 is offline   Reply With Quote
Old 09-21-2016, 10:32 AM   #5
Don't be so quick to blame the water pump,the Pex lines can Really make a Drumming/Thumping noise! Adding a Accumulator can improve a RV water system as well! Youroo!!
Old 09-21-2016, 11:45 AM   #6
I agree it is very loud I have thought of mounting mine on a rubber mat as currently it is screwed to the floor. I think the floor amplifies the sound.
Old 09-21-2016, 02:59 PM   #7
MNtraveler's Avatar
In the 2401R it's in the outside driver's side compartment where the winterize switch is, inside an inner compartment door. Very accessible to any baby monkey.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 29; RV to date: 32
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 10-15-2016, 01:23 PM   #8
The water pump on a Forest River Forester 2401w is inside under the shower through an access panel. Four screws hold it in place. I believe me handle next to the access panel is a shut off valve that shuts off the water from the fresh water tank and then allows you to use the loose hose to siphon the rv antifreeze for winterization.
jeitel55 is offline   Reply With Quote
cat, location, pump, water, water pump
