06-28-2016, 10:53 AM
#21
Newly Retired
Would this type spring add on help me? With cargo in my toy hauler, I am bottoming out. 30 foot TT.
06-28-2016, 11:13 AM
#22
Sumo only produces their product for actual vehicles. Since our motor homes are on a MBS Sprinter chassis, they have a product for us on this MBS sub forum.
There may be other solutions for your TT issues, but not in a Sumo product.
Pod2Vibe
Magnetic 2019 Isata 5 30FW 4X4 (arrived 2/15/19)
TOAD: 2014 Fiat 500 Abarth
2015 Solera MBS 24R - Hellwig/Sumo Equipped, Sold
(Sold the Vibe TT, as well)
06-29-2016, 05:47 AM
#23
I would call the people at etrailer.com If something is possible, they can help you with it. If not, they usually suggest who can.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
09-04-2016, 04:56 PM
#24
Dealer won't install Sumos
I bought a set from eTrailer and tried to get the local dealer to install them. They said they would not fit. So I took the Prism to the next town over and ask the dealer there to install them and they said they would not fit. I verified with eTrailer and Sumo that I had the correct one for my rig.
If you don't buy the parts from the dealer so they can get their 20% markup they come up with some reason to not work on your rig.
09-04-2016, 05:17 PM
#25
YouTube has a few videos on how to do it, if you lived in the Boise just west of me I would help.
Simple just slide them in and tie them down.
09-13-2016, 06:09 AM
#26
I have a 2 month old 2401w. Will installing the sumos effect the MB warranty ?
2016 Forester 2401W newbie
09-13-2016, 07:07 AM
#27
NO, all you are doing is replacing the existing JOUNCE bumpers with an after market one that fills the entire gap between the frame and axle/lower control arm instead of leaving a gap.
09-25-2016, 09:07 PM
#28
Added the sumos. Definitely helps the problem with pulling out of driveways and gas stations where an slow speed bump or turn would generate a back and forth roll that would try to throw every item off the shelves. The one thing I wanted to correct. But I have noticed that it now seems a little more sensitive to cross wind. And one else experiencing this?
09-25-2016, 09:23 PM
#29
I put sumos all the way around and bilstein heavy duty on rear and makes an enormous difference in cross winds . Much more in control. Ride is a little rougher but handling, especially on mt roads much better. Came home today during a Santa Ana wind storm and no problem
11-24-2016, 10:33 AM
#30
Sumospring Installation
I just installed front and rear Sumosprings on my 2017 MBS 2400R. I highly recommend them. I bought them at SDTrucksprings.com for $355 total. The ride and handling is much better, and I still have the oem shocks.
The install took a total of 2 hours, mostly due to my learning curve. The first one of each was a pain until I learned the procedure, and the second was a piece of cake, and I am 65 and not a mechanic. For those who might be hesitant to attack the job, here is how I did it.
On the front, I just jacked up one side at a time high enough to open the space where the bump stops are, and turned the wheel to the outside to make room. I removed the old stops with a 13mm socket. Getting the new ones in was a little tight but they went in. Threading the washer and nut onto the new one was a challenge because the bolt was down in a hole and I knew I would drop the nut in it. I used some tacky glue to hold the washer and nut in the socket and it worked like a charm. You will need a deep well 13mm socket to tighten it.
On the rear, I used the stabilizers to raise the frame enough to open the space above the axle. The old ones just pull off with a little twist. Following the instructions to install the new ones, tuck the larger tab into the front of the bracket. I then tried to bend, twist and pry the rear tab in to no avail. I then just pushed straight up and the rear tab popped in. It was almost too easy.
Retract the stabilizers, put away the tools and go for a ride. You won’t be disappointed. I hope that this helps someone save the cost of installation. If I can do it, you can too.
2017 Sunseeker MBS 2400R
11-24-2016, 12:52 PM
#31
Just remember if you spray silicone on the old rear ones they come out super easy..
John Craft
dogpa
2016 Solera 24R
12-07-2016, 12:45 PM
#32
Are the sumos for the 2016 mbs like a solid block of.black rubber??
