Old 07-27-2016, 01:59 AM   #21
dukeboone's Avatar
2x 160w solar
BlueSky 2512ix MPPT Controller
BlueSky IPN ProRemote
Progressive Industries EMS w/ Remote Display
Metal Valve Stems
TPMS
Sumo Springs
Rear Bed Shelving
Upgraded Curt Controller...
Regarding the coach audio receiver my "C" speaker is wired to a subwoofer located underneath the front most dinette bench. Adjusted the bass down quite a bit and it sounds quite good now. I suspect the subwoofer is located in different areas depending on the floor plan. My HDMI cables needed to be swapped on the overhead bunk TV, and now all the A/V inputs work properly.
Cheers
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 07-27-2016, 09:33 AM   #22
Originally Posted by namusmc View Post
Remove the two drawers from the closet. In the rear of the opening you should find a small subwoofer with a volume control mounted on the floor. You can reach in the opening and fiddle with the controls. The system actually sounds pretty decent once you get the sub adjusted to your liking.
Thanks for the response. I checked that out. no luck. The MBS 2400WS has a full drivers side slide out with the clothes closet as well as the drawers residing within it. Due to this, all the wiring for the slide out devices come up through the bottom of the stationary part of the bed, then down alongside the slide out, underneath it and then enter into the area behind the drawers. When I took out the drawers, I did find a green/white lamp cord so I started tracing where it went. Two hours later, after crawling under the motor home trying to trace the wires, opening evey cover inside. removing the master switch panel, and the Electrical distribution center. I figured out that the green/white lamp cord I was tracing was for the drivers side exterior light that is in the slide out. I never did find the "C" channel wire I was looking for but I did find the Generator Transfer Switch.
If you have a 2400W or a 2401W, the transfer switch is located behind a panel in the driver side rear garage compartment. There should be a box out on the left with 4 screws. Remove the screws, corner trim, and paneling to access transfer switch. I never did try and figure out how to remove its cover though.
I also found that some wiring runs underneath either encased in sealtite or wire loom. There is also some wiring that was snaked through the floor framing.
The 110 volt feed from the transfer switch runs in between the floor and under the spot that I installed the safe. The floor is 3/4" sheeting so if you do install the safe where I did, keep that in mind when drilling a pilot hole and choosing the length of the lag bolts you use.
BTW, If anyone ever figures out how to take the speaker covers off without damaging them or the soft ceiling, I would appreciate knowing. Accessing that area is my next project should I find time to search for the "C" channel speaker wiring.
It sure would be nice if Forest River had a wiring schematic showing the wire coloring, which device it was for and where it was fed from. The electrical installers had to have something to work by.
ShermanD is offline   Reply With Quote
Old 07-29-2016, 09:17 PM   #23
Farkasb's Avatar
Here are updates to my 2401WS:
Picked my unit up in October 2015 and the first thing I did before leaving the lot was duct-tape a Ziploc bag around the curt controller. Thanks to everyone talking about it here on the forum. Didn't bother mentioning it to the dealer because I knew what would happen, nothing.
Progressive Industries EMS-HW30C installed in night stand next to bed (thanks for the idea Kysunseekermbs)
Sumo springs front and rear
Cut open access to area behind TV for extra storage. Have the entertainment center option with the large cap.
Ran Optical cable from the Jensen JWM6A to the 42" TV for surround sound
Refurbished Roku for TV
Dimmer switch for dinette lights
LED light for range hood (thanks Backdoctor)
Extenda stay hose for propane
Screen door guard and screen door bar/handle.
Maxxfan deluxe for bedroom
Moved bedroom maxxfan into bathroom
Roof mounted solar panels 160W and 100W panels
1500W inverter hard wired into the breaker with second transfer switch, remote on/off switch at convenience center above fridge
Oxygenics Shower head
Shower faucet
Bathroom faucet
Sunscreens for cab Windows
Easy curtain for blackout of cab Windows.Easy Living Industries
Removed the Velcro buttons from stock curtain and replaced with Silver Grey Hinged screw Snap-Caps
Added 2 shelves to back cubby in wardrobe
Also had a few issues:
Mercedes issue had a transmission cooling pipe leaking, fixed under warranty
Screws missing in slide bracket , fixed under warranty
Minor leak coming from under the wardrobe due to gaps in calking on outside of slide molding, fixed under warranty
Leak in front cap that came through the visor, same as many others have reported. Had it in to the shop four times before we finally figured out the issue. To help troubleshoot I ended up removing all the plastic molding and visor molding to examine inside the cap easier, also bought a scope camera to thoroughly look around in there.
1st attempt the shop touched up the calk around the cap and sealed around the clearance lights. Still water entering the cap. 2nd time into the shop was the first pressure test and it only showed one clearance light had a slight leak. They sealed that and also touched up the dicor at the end of gutters. I still had water coming into the cap when it rained. 3rd time in the pressure test showed no leaks they were still baffled and re-calked a few areas around the cap and gutters. Water still coming in the cap not much but any amount is too much. The fourth time into the shop they gathered a few techs and we went over all the scenarios. The one area I always questioned ended up being the culprit. My unit does not have gutters up front so the water runs right down the outside of the cap. It comes down hugging the side with such force or suction that it defies gravity and wraps around to the cab window. There some kind of molding or spacer there that was letting water in. Attached is a photo of that area. When the shop took off the molding there was a gap at the front corner that opened to the interior of the cap letting water in. They calked the gap and along that molding section on both sides of the coach. I still have one piece of molding off so I can monitor for any leaks DW hates it but I need my piece of mind. The plan is to have front gutters put on this fall, hopefully under warranty.
I must say even though this was a pain and a hassle the shop (not who I bought from) was very accommodating compared to other experiences I have read on this forum.
Name:	Screen Shot 2016-07-29 at 5.43.47 PM.png
ID:	115776   Click image for larger version
ID:	115793   Click image for larger version
ID:	115794   Click image for larger version
ID:	115795   Click image for larger version
ID:	115797   Click image for larger version
ID:	115798   Click image for larger version
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 08-01-2016, 11:09 AM   #24
Thumbs up One Necessary Mod - carryover from Travel Trailer days
For years I always moved my Streamlight 'stinger' rechargeable flashlight from travel-trailer to travel-trailer. However, I let it go with the last TT.
I just happened to see the latest Strion LED on a clearance table at Gander Mountain - had to have it.
https://www.amazon.com/Streamlight-7...+strion+led+hl
I will mount it on the wall below the sink as you walk in the door next to the switches / battery disconnect. Will also wire it in under the cabinet to 12v for charging.
This is a great little light, and puts the Stinger to shame. 505 5-star reviews
nusslejj is offline   Reply With Quote
Old 08-01-2016, 12:04 PM   #25
Tiny LED Lanterns- fit in a cup holder yet provide lots of ligtht
We found these cute little LED lanterns on Amazon.com. They are a prime item. What is real nice about then is that they will fit in the corner cup holders on the slide out dinette. The use AA batteries, so you could put re-chargeable batteries in them if you wanted to.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-01-2016, 02:39 PM   #26
2015 Forester MBS 2401W
HomeOnWheels's Avatar
twist on waste valve
Among many things I added to our W, the twist on waste valve is something I would rather not have to have. After three failures of black tank valve and one failure of grey valve, I believe there is an inherent design flaw. By adding this twist on valve, it at least won't cause a stinky mess.
ID:	116003   Click image for larger version
Jeff
HomeOnWheels is offline   Reply With Quote
Old 08-03-2016, 10:29 PM   #27
Farkasb's Avatar
Originally Posted by ShermanD View Post
I think I am finished customizing our Sunseeker MBS2400WS for now.
accomplishments.
Added Tekonsha Prodigy P2 brake controller.
Added back-up camera to Transport trailer - hardwired into Jenson in dash system.
Added Extenda-stay propane valve and hoses.
Added Water Pump switch in bathroom.
Added elastic strips to movable half of mattress - pulls mattress half out on slide out extension. One push and bed is maid.
Added small safe to cubby under bed.
Build new knife holder that replaces existing one.
Added Sumosprings SSR-338-47 to rear suspension
Added Sumosprings SSF-106-40 to front suspension
Installed missing valve stem extensions
Added Carefree EZ ZipBlocker 15x8 sun shade to awning
Added A-Z covers 3 piece window insulation set
Added additional shelving in pantry
Removed Bedroom Curtain
Customized privacy curtain separating cab from camper.
No wonder I have been so tired lately!!!
Hey Sherman, I noticed your Dyson is mounted next to the entrance door. Did it come that way from the factory?
Mine came mounted in the long narrow storage bay at the back on the driver side.
Old 08-22-2016, 09:59 PM   #28
raptor's Avatar
Hi ShermanD,
Is these added Sumo springs SSR-338-47 to rear suspension and Sumo springs SSF-106-40 to front suspension working much better for you? How much are they and where did you get it? Would Les Swab do the installation?
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 08-23-2016, 08:10 PM   #29
dukeboone's Avatar
Originally Posted by raptor View Post
Hi ShermanD,
I have the SSR-338-47 on the rear, did the installation myself but I'm confident that Les Schwab would do the installation. The rear are very easy. Haven't done the front yet, but still may do that. Looks a little more difficult and might have Les Schwab do it for me if I go that route.
Old 08-23-2016, 11:27 PM   #30
I've noticed that some forum members have installed front Timbren "springs" instead of the Sumos. I have Sumos on the rear, which I really like, but am wondering if any members have comments about the Timbrens front installation ease and function vs the Sumos front installation and function.
namusmc is offline   Reply With Quote
