Old 09-30-2018, 07:43 AM   #1
Wheel spacers instead of Sumo springs
Looking at how deep the wheels are set in on the sprinter chassis. Wondering if anyone has used spacers (recommended I could go up to two inches) instead of sumo springs. Anything bad I have read about spacers seems to be user error.
Go UK is offline   Reply With Quote
Old 09-30-2018, 08:01 AM   #2
Chuck_S's Avatar
Everything I've read or experienced about wheel spacers is they put abnormal and often excessive strains on the axles. bearings, etc. And that's with spacers as small as 5mm, nut 50mm (~2 inches).
-- Chuck
Chuck_S is offline   Reply With Quote
Old 09-30-2018, 08:03 AM   #3
The need for Sumo Springs or Wheel Spacers sounds like a Overload Condition! Youroo! !
Old 09-30-2018, 09:33 AM   #4
Well...that's because of a number of shortcomings of the MBS based motorhomes.
The first is that the Sprinter has a GVWR of 11,300 lbs...and most of the motorhomes come off the assembly line weighing 10,000 lbs or more. So all of them are right up against that limit immediately.
The second is that, in their wisdom, Mercedes has been unwilling to produce a modified Sprinter chassis with more rear axle width. So motorhomes, which can be a little top heavy, strain against a relatively narrow base.
And a third is that, again in their wisdom, Mercedes delivers their chassis with suspension components which, as near as I can tell, assume that the vehicle will almost never bump up against the GVWR. Their springs, shocks, and anti-roll bars all tend to be just barely sufficient and much better performance is obtained when some, or all, of those components are upgraded.
I suppose we can't lay all the blame on Mercedes - the motorhome builders have to take some responsibility for shipping products which are right up against the GVWR even though they're aware of the problems. FR, at least, went to the extent of upgrading the rear anti-roll bar (are they still doing that?) which certainly helped.
Ah well. Other than that, it's a very user-friendly chassis!
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 09-30-2018, 09:44 AM   #5
Who Dares, Wins
doc73's Avatar
Depending on where you live wheel spacers are not legal. I would never do 2" that seems to me like a disaster waiting to happen. 1/4" is the may we can do here in PA as an idea what I mean.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 09-30-2018, 10:58 AM   #6
chroniekon's Avatar
I think spacing the wheels out isn't going to help much. The springs and frame still remains the same width. Which in my option is to close together
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 09-30-2018, 11:15 AM   #7
Dave X2
We all do what we can to minimize or lower the coach weight i.e. remove rear wood door, swap out shower door and installing aftermarket items like Summos or upgraded shocks makes it worth it. But I for one Am very cognizant of being overloaded.
Travel safe.
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 09-30-2018, 01:18 PM   #8
Not sure why you would say that. Wheel spacers or Sumo springs will not alleviate an over load condition in that they allow more weight. They will however help the ride, and in the case of the OP broaden the axle width leading to a more stable ride.
I will be adding Sumo Springs soon not because I am overloaded but because of the additional ride enhancement.
cariboo camper is offline   Reply With Quote
Old 09-30-2018, 02:53 PM   #9
mlmay12's Avatar
I have 1.5 inch Spidertrax Spacers on my Jeep for clearance but would not put them on my heavy Sprinter Chassis. Might want to look into the effects on Warranty first as MB is very strict about every thing.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Mister Jake(RIP), Casey & Baby Chubbs
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 09-30-2018, 02:58 PM   #10
Mtnman64's Avatar
MBS
Would have better luck changing the rear axle, for width and weight capacity. The sumo springs just add to the ride comfort and are not about being able to carry more weight. Overall, I still love my MBS Sunseeker after two years and 14K smiles on the road.
Mtnman64 is offline   Reply With Quote
wheel
